nathanway Member 106 Member For: 13y 6m 11d Gender: Male Location: townsville Posted 08/11/13 03:07 AM Share Posted 08/11/13 03:07 AM hello all. ive just got my 08 fg turbo auto back from the shop , if anyone can remember I had a post up getting advice on what I should get done, original plan was to get my turbo front cover changed and upgrade the waste gate and actuator and go for 370-400rwkw but I ended up being about $1000 short so I coulnt afford to get the turbo and fuel pump done so I stuck with the stock turbo ,the end result is impressive bottom end power but its a bit dull in the top end, I find that if I change gears at about 4500 rpm it gos way harder and will spin the tyres but it seems to drop away after 5000 , so the car apparently makes 302.9rwkw @about 4900rpm and 1226NM @ 3180rpm @ 20-21psi of boost no boost graphs were given so I cant confirm this its just what they said also cant see if its holding that pressure all the way through the rev range I suspect its dropping in the higher revsmods includerapid systems v2 pipe's cooler and turbo side intakeExforce 4inch turbo back system mild steelH/D valve springsinjectors ( doesn't say what size or brand)x-cal 3 and dyno tunenow that you know how the cars set up my main concern isboost pressurelack of boost control ( max boost)and lower than average power for more boost than most people with same powermore torque than most people with the same power (dyno run in 3rd)dyno shop is known for good work and wasn't cheapthey said it was safe and that the auto box was the reason its not making the 320-330kw mark but at the same time ive got friends with similer mods making more but through different dyno companys with the auto + countless people on hear saying they made a little over 320 so im a little bit worried that somthings not quite rightany info or advice pointers would be would be sweetThanks Link to comment Share on other sites More sharing options...
Rab WOT? Moderating Team 10,981 Member For: 11y 11m 23d Gender: Male Location: Frankston, 3199 Posted 08/11/13 03:19 AM Share Posted 08/11/13 03:19 AM I'm sure I'm wrong, but that seems like a huge amount of torque (and drops off pretty quick)? Link to comment Share on other sites More sharing options...
fatz_f6_typhoon Member 395 Member For: 12y 1m 16d Gender: Male Location: 2145 nsw Posted 08/11/13 03:39 AM Share Posted 08/11/13 03:39 AM Hmmm maybe some advice from ratter May shed some light on it???..... Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 21d Gender: Male Location: @ my laptop Posted 08/11/13 03:56 AM Share Posted 08/11/13 03:56 AM the small turbo will never hold boost in the top end on these engines, it's just too small Link to comment Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 3m 8d Gender: Male Location: left right out Posted 08/11/13 04:22 AM Share Posted 08/11/13 04:22 AM Run done in 3rd accoring to the graph, hence mucho torquo, prob about 850nm in 4th at a guess. Link to comment Share on other sites More sharing options...
nathanway Member 106 Member For: 13y 6m 11d Gender: Male Location: townsville Posted 08/11/13 04:52 AM Author Share Posted 08/11/13 04:52 AM I asked him about doing the waste gate and the actuator and he said its not worth it ,my understanding is limited but my thinking isthe hole and flapper are to small, down low rpms this causes spike because it cant divert the exhaust around the turbine fast enough ,but once the motor starts to rev high and need large volumes of air it needs to close the gate to increase the turbine speed to increase the volume of air to maintain the pressure levels I know at this stage the turbo is starting to run out of puff but if the gate isn't fully closed that would cause the turbo to not hit max rpm/ flow and drop pressure a little earlier and more in the topend resulting in the lower peak output... but im no mechanic and don't realty know what im talking about but could just be the the actuator isn't right and that's the reason for the only 302kw instead of 320-330its 20kw down on what everyone else's has made could it just be a low reading dyno +the auto but still seems a lot low, just a bit annoyed when others have only done the injectors and the tune and made 300 Link to comment Share on other sites More sharing options...
sct911 Member 848 Member For: 12y 3m 11d Gender: Male Posted 08/11/13 05:00 AM Share Posted 08/11/13 05:00 AM drag strip will tell the real story Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 25d Gender: Male Location: Perth Posted 08/11/13 05:02 AM Share Posted 08/11/13 05:02 AM the small turbo will never hold boost in the top end on these engines, it's just too smallWhats the max boost you tend to see them able to hold up top Mick?Im playing around with one at the moment on a BF motor but haven't been able to wind it up due to a spongy stock actuator. Link to comment Share on other sites More sharing options...
nathanway Member 106 Member For: 13y 6m 11d Gender: Male Location: townsville Posted 08/11/13 05:24 AM Author Share Posted 08/11/13 05:24 AM ive had it down the strip when it was stock and got a 12.9@ 107mph with a 2.0 60footgoal is to get a 11.xx but I don't think 302 is enough to , all the ones ive seen with 300 getting low 12 passes Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 26d Gender: Male Location: Perth, WA Posted 08/11/13 05:47 AM Share Posted 08/11/13 05:47 AM Whats the max boost you tend to see them able to hold up top Mick?Im playing around with one at the moment on a BF motor but haven't been able to wind it up due to a spongy stock actuator.+1 I too would like to know what the max boost a GT3576 can hold up top?I have been keeping an eye on most of the stock turbo results posted here and it seems like the ones who run a completely stock GT3576 may hold 10-11psi max above 4500rpm and make around 300 at the wheels.There have been a couple of example where actuators were done and they managed to hold 13-14psi and make around 330 at the wheels mark.I guess there is a lot of other factors too, but am curious to know if a port job and actuator are worth it on a GT3576 to get that little extra top end? Link to comment Share on other sites More sharing options...
