RBSMATT New Member 18 Member For: 17y 2m 4d Gender: Male Posted 10/09/14 11:48 PM Share Posted 10/09/14 11:48 PM (edited) High initial bite = dust and generally some pad squealLow initial bite = low dust low rotor wearMost people ask for low dust low noise and low rotor wear but there has to be a comprimise somewhere. Ferodo DS Performance pads are pretty good all round and will not fade out on the street and you don't generally get that resin issue on the rotor face like some of the other pads out there ( I won't name them). Bremtec Endure are a low dust heavy duty pad but because of the low dust low rotor wear they lose a little bit of initial bite but they have pregressive braking and find they work well for everyday driving. If a rotor has slight run out then don't expect brake pads to fix the issue it is more likely warped but don't confuse that witha more common problem of resin build up on the rotor face around the slots and using the brakes more aggressively can sometimes wipe that away. GCT pads and some EBC are common brand pads than we have seen have issues with and why there not generaly recommended. I have to disagree and say not all performance pads will eat rotors and that FGXR6T rotors are like the DBA 4000 T3 rotors without slots I can't imagine Ford spending that much money on there rotors and I mean for staters they don't have the Kangaroo paw design or TSP which is Thermal Stability Profiling. Most peple just do front upgrades but I mean put a full set of DS Performance pads and DBA T3 Slotted on your car for instance and you will be guarenteed shorter stopping distances and no brake fade on the street. Edited 10/09/14 11:49 PM by RBSMATT Link to comment https://www.fordxr6turbo.com/forum/topic/86710-which-brake-pads/page/3/#findComment-1498535 Share on other sites More sharing options...
raised by monkeys Member 90 Member For: 10y 9m Gender: Male Location: Whyalla, SA Posted 14/10/14 06:18 AM Share Posted 14/10/14 06:18 AM So I just told my mechanic to slap on some EBC red's with new dimpled rotors. Want the performance not too worried about noise. Hope ive made the right choice :/ Link to comment https://www.fordxr6turbo.com/forum/topic/86710-which-brake-pads/page/3/#findComment-1506142 Share on other sites More sharing options...
Bulletime Donating Members 937 Member For: 14y 5m 2d Gender: Male Posted 14/10/14 10:14 AM Share Posted 14/10/14 10:14 AM Great pad for the street, plenty of bite. Link to comment https://www.fordxr6turbo.com/forum/topic/86710-which-brake-pads/page/3/#findComment-1506191 Share on other sites More sharing options...
nelsonian101 Donating Members 961 Member For: 16y 11m 17d Gender: Male Location: Sydney Posted 15/10/14 12:48 AM Share Posted 15/10/14 12:48 AM Can anyone recommend a circuit/track only pad that fit the rear PBR Territory/FPV single pot calipers (328mm rotor)?I'll be searching the World Time attack sponsors at SMP this weekend for suggestions too.So far I've only been using Race pads (PMu H16-03) in the front and just the Ferodo DS on the back.Any ideas for the highest performance pad available for the rears? Link to comment https://www.fordxr6turbo.com/forum/topic/86710-which-brake-pads/page/3/#findComment-1506240 Share on other sites More sharing options...
julesk_1972 Member 267 Member For: 12y 10m 17d Gender: Male Location: Perth Posted 15/10/14 01:43 PM Share Posted 15/10/14 01:43 PM http://qfm.com.au/page/6/Performance_Range Link to comment https://www.fordxr6turbo.com/forum/topic/86710-which-brake-pads/page/3/#findComment-1506354 Share on other sites More sharing options...
