  • New Member
  • Member For: 12y 6m 21d
Hi all, my 03 XR6T is having some issues, had problems with overboost, mainly in the cold. Ive had dtc P1131, P1132 and P1227 and replaced the O2 sensor twice. Codes, and boost of up to 8psi, were detected on Torque app which is now also showing "open loop system fail" and car is intermittently idling really rough. Im assuming, even if the O2 sensor is gone again, the problem is elsewhere. Any help greatly appreciated. I'd like to fix it myself as I don't know of any good tuners around here.
post-53743-0-26007000-1383656516_thumb.p
Edited by FoMoCoMoFo
https://www.fordxr6turbo.com/forum/topic/86706-open-loop/
  • New Member
Replaced the o2 again, all seems fine.....for now, 3rd o2 in 12 months! Either I'm very unlucky or something is causing them to fail.
https://www.fordxr6turbo.com/forum/topic/86706-open-loop/#findComment-1440017
  • Member For: 12y 9m 23d
mines the same, replaced 02 sensor nd after 3 months failed, so replaced under warrenty and now its the same again......with bosch sensor and ebay PEX? sensors
https://www.fordxr6turbo.com/forum/topic/86706-open-loop/#findComment-1440026
  • 5 months later...
