  • Member For: 20y 10m 20d
Is your rear 0.82 housing a garrett or precision housing. Internal or external gate? Would like to see some picks if possible?
  • Member For: 17y 7m 5d
Just looking at the high stall speed, wouldn't you be best going for something like a 2500rpm stall speed rather than 4000 ??
Would pick up a load of power there alone I would think, especially if the turbo crack's gate at like 2000rpm or less...
  • in the mid....not the bum like some
  • Member For: 12y 1m 19d
Nope I want the power big off the converter and only 12-1300rpm drop when changing gears.
All parts have been selected for a outcome.
I will be running higher gate pressure also along with wanting to cut .4x reaction times my car will be competing in a class.
Edited by Skids4kids
Thanks for the pic skids. Looked at a garrett 0.82 housing for my pt6235. Was advised that it was too small and the backpressure/heat build up would put my stock engine at risk.
Your in a better position with your built engine, look forward to seeing how that turbo combo goes for you. Why did you relocate your power steering resovoir?
I run the FG manifold so back pressure is not as high as a B series would be.
Power steering was relocated so my intake had heaps of room Im not a fan of sh*t all cramped up.
Does anybody know if the internal gate PT6466 will bolt directly up to a FG Nizpro dump pipe ??
Is there ANY mod's needed at all , as I read previously 20mm has to be chopped out is that correct ??
  • Waiting for the 1st N/A 12!
  • Member For: 17y 4m
An internally gated MTA900 did 595 rwkws this today with1.06 rear with 19 psi actuator.
  • Like 2
