  • Waiting for the 1st N/A 12!
  • Member For: 17y 2m 15d
  • To Loud
  • Member For: 13y 4m 27d
  • Member For: 17y 5m 21d
Ok got a reply back and this was what he said word for word....
" No problem, just take this as a rough estimate, as we may even package it up at a different price when we put them together, but going off a GTW BALL BEARING Supercore with XR6T Exhaust Housing fitted, and using our custom made bracketry for the actuator ( To suit the Larger .70a/r front housing ), it's comes out to $2680 BB version, In the bush bearing version it would be $2150. Regards "
Rough estimation he said, could be a little more, could be a little less, but I'd say it would be pretty much spot on for price I reckon...
  • Member For: 20y 9m 4d
Not bad pricing. Would be cheaper than the borg warner efr where everything needs to be re-engineered and in the ballpark price of the precision bolt-ons.
If it spools quicker than the gtx3582, and has garrett reliability you could not go wrong
  • in the mid....not the bum like some
  • Member For: 12y 3d
Borg warner only needs the front part of dump modified,power steering relocation which I just did on mine for under $200 and the intake tweaked a little if it suited a Garrett beforehand.
9180 will be my next choice of turbo when I get a stronger trans than the BTR....I think the 9180 has enough in her to eclipse the 6466 and not be bugger all more laggy.
The GTW range is a great addition to Garrett...sizing they were really missing.
Expect them to make claimed figures which is a good thing....spool Im not convinced on yet in regards to say a 6466 in comparison...its going to spool the same as the GTX at best but that's not laggy by any means.
Ratings are usually made with turbo being in T4 guise also...knock 50hp off whatever they say if running T3....same with any brand.
skids4kids, I see in down the bottom of your name it say's you have a precision 6466 fitted to your's, what RPM does it start spooiling and what RPM does it hit full boost ??
Must be pretty snappy with a .82 exhaust housing ???
Haven't used mine yet just finishing the fuel system.
The peak of 850hp is ample for myself as it will spin up well over 400rwkw at 100kmhr with my setup and still push high into the 400s till redline at moderate boost.
I'm after more average power than just peak so to speak.
With my converter its hard to say when its going to spool as its going to flash to 4k straight away....I know on a stock ZF the same turbo as mine has the gate cracked just loading her up at idle ;)
  • Like 2
