vixenf6 Member 84 Member For: 11y 5m 21d Gender: Male Posted 31/10/13 12:31 PM Share Posted 31/10/13 12:31 PM Does any one know the name of the bolt washer thingy-ma-jigs what stop the manifolds bolts from coming loose? I remember something about nizpro selling them but they cost a fortune,My uncle was a pilot and said they use something similar to these on planes shaped like a triangle and stop the bolt unwinding ?Any help would be great because old mate who just bought a turbo ute has lost 2 bolts from the previous owner and the rest are finger tight. Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 16d Gender: Male Location: Christchurch, New Zealand Posted 31/10/13 09:29 PM Share Posted 31/10/13 09:29 PM Atomic Performance version is Anchorlox. As for on planes they use lock tab washers or lockwire which are slightly different to these. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 11d Gender: Male Location: Perth Posted 01/11/13 03:45 AM Share Posted 01/11/13 03:45 AM Just use there:http://www.nord-lock.com/products/wedge-locking/washers/introduction/Cheap and effective. I get them from Coventrys Fasteners over here in WA , so any industrial fastener joint should carry them 1 Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m 11d Gender: Male Location: Maryborough Qld Posted 01/11/13 06:25 AM Share Posted 01/11/13 06:25 AM with the manifold bolts on a ba xr6t would it be better to use studs not bolts? or is bolts better? Link to comment Share on other sites More sharing options...
vixenf6 Member 84 Member For: 11y 5m 21d Gender: Male Posted 01/11/13 01:14 PM Author Share Posted 01/11/13 01:14 PM Atomic Performance version is Anchorlox. As for on planes they use lock tab washers or lockwire which are slightly different to these.Just use there:http://www.nord-lock.com/products/wedge-locking/washers/introduction/Cheap and effective. I get them from Coventrys Fasteners over here in WA , so any industrial fastener joint should carry themThanks for the replies. will pass on info Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 1m 16d Gender: Male Location: Christchurch, New Zealand Posted 02/11/13 07:53 AM Share Posted 02/11/13 07:53 AM with the manifold bolts on a ba xr6t would it be better to use studs not bolts? or is bolts better?Either are fine, I have put studs in so that the thread holes in the block are less likely to get stuffed. Fraud when servicing it had done a good job of near Fkn some so just put studs in to save it. Link to comment Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 7m 11d Gender: Male Location: Maryborough Qld Posted 02/11/13 09:01 AM Share Posted 02/11/13 09:01 AM yeah I have a couple threads in teh head that need repairing...ffs dont let ya dickead mate help ya haha.easy fix with heli coil but need to find the time. I think ill put studs in it, can get em for like 10 bucks on ebay for 10 that are suited for exhausts. I have the sonic kit in the manifold to turbo and there tight as after 7000ks, before it was bolts...for sum reason....anyway they loosened up after about 500ks... Link to comment Share on other sites More sharing options...
lodi77 Member 7 Member For: 11y 4m 4d Gender: Male Posted 03/11/13 02:07 AM Share Posted 03/11/13 02:07 AM I have studs and nord lock washers, didn't stop it from loosening, my exhaust was causing the problem as the weight was to hard on the manifold, welded a bracket to the exhaust and bolted it to the gearbox. Seems to be better but it's a standard problem if you like to rev to the redline. Tighten every 4-6 weeks. Link to comment Share on other sites More sharing options...
turbotrana Member 2,586 Member For: 21y 11m 4d Gender: Male Posted 03/11/13 06:03 AM Share Posted 03/11/13 06:03 AM I don't think using studs for anything turbo works very well.For the head/manifold I use allen key headed bolts with nordlocks. With the manifold to turbo I use special turbo locking nuts and lock tabs. Whenever I design my custom manifolds I usually make the turbo mounting plate so that it can have a bolt pass thru to bolt the turbo on with turbo lock nuts and never had a problem. I would never consider studs as I know how many headaches they caused me on my very first setup. Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 5m 11d Gender: Male Location: Perth Posted 03/11/13 07:16 AM Share Posted 03/11/13 07:16 AM Im a fan of studs but only if there are long enough to allow a compression spacer to be used. Otherwise decent bolts/nordlocs/correct torque is the way to go. Link to comment Share on other sites More sharing options...
