NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 2m 7d Gender: Male Location: Perth, WA Posted 22/01/15 10:44 AM Share Posted 22/01/15 10:44 AM ^ Agreed.RDA = Rubbish. Also RDA customer service don't give a sh*t...DBA T2/T3 with a nice pad and 5.1 fluid = win Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525359 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 8m 6d Gender: Male Location: Adelaide Posted 22/01/15 10:50 AM Share Posted 22/01/15 10:50 AM Report back. Rda ARE sh*t!!!! Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525362 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 16d Gender: Male Location: Perth Posted 22/01/15 11:09 AM Share Posted 22/01/15 11:09 AM I have RDA dimpled on 3 cars. They are fine. Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525365 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 11m 11d Gender: Male Location: Western Sydney Posted 22/01/15 11:22 AM Share Posted 22/01/15 11:22 AM Never had a problem with RDA. I think it's more pad choice they go well with aggressive pads. Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525369 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 4m 13d Gender: Male Location: WA, Perth Posted 22/01/15 11:35 AM Share Posted 22/01/15 11:35 AM What a way to dig up an old thread. I think I have to agree with Ozwalker. It has to do with pads.I have DBA T3s and I had shudder.I believe that when the endures get sent back and either the Bendix ultimates or the project MUs go in, the shudder will go away. Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525373 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 11m 11d Gender: Male Location: Western Sydney Posted 22/01/15 11:44 AM Share Posted 22/01/15 11:44 AM Or ferodo DS Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525378 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 10m 18d Gender: Male Location: NOR Perth Posted 23/01/15 01:01 AM Author Share Posted 23/01/15 01:01 AM So is the key with RDA to run aggressive pads? I always thought the harsher the pads the more prone the rotors are to becoming warped/shudderOzywalker I assume you use DS250 or whatever they are called? Arronm you use bendix ultimates yeah? Would these bremtec endures be considered a soft pad? And therefore prone to leaving resin; where a harsh pad will almost act like a constant machining for the rotors? Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525430 Share on other sites More sharing options...
OZYWALKER XR50T Gold Donating Members 2,795 Member For: 11y 11m 11d Gender: Male Location: Western Sydney Posted 23/01/15 01:22 AM Share Posted 23/01/15 01:22 AM Not really sure about the bremtecs. I've always gone for high temp rated pads and found the ferodo DS2500 pretty good and the remsas where also pretty good.But It's not a daily and gets driven hard, only really get 5 to 7k out of a set of pads maybe 10 to 15k from the rotors.Need brembos. Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525436 Share on other sites More sharing options...
PTR_NITRO_FG Donating Members 3,214 Member For: 11y 10m 18d Gender: Male Location: NOR Perth Posted 23/01/15 01:42 AM Author Share Posted 23/01/15 01:42 AM yeh DS2500 is the ones I mean lolbloody bremtecs....not sure if my rotor/pad compatibility is the cause of my premature rotor wear...but I will be machining the discs once I sort out some front bushes....so I figure I may as well try new pads just in case the bremtecs were the cause.and see 10-15k kms is not normal to me. Mines basically a daily....and rotors usually last 50,000kms+ or so (with one machine during that time)...pretty sure I even read they can last 100,000kms? (Stever?)....replacing that often I can see why you prefer to go through rdas....imagine the cost if you were burning through t3's that quickly Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525443 Share on other sites More sharing options...
barnz Member 3,047 Member For: 11y 4m 23d Gender: Male Location: Brisbane Posted 23/01/15 01:45 AM Share Posted 23/01/15 01:45 AM On 23/01/2015 at 1:01 AM, PTR_NITRO_FG said: So is the key with RDA to run aggressive pads? I always thought the harsher the pads the more prone the rotors are to becoming warped/shudderOzywalker I assume you use DS250 or whatever they are called? Arronm you use bendix ultimates yeah? Would these bremtec endures be considered a soft pad? And therefore prone to leaving resin; where a harsh pad will almost act like a constant machining for the rotors?Correct in a way, expect to change rotors every 3rd pad change with aggressive pads(2 sets of pads to one set of rotors) depending on how much of a hiding they get. Still quite alot of km's though Link to comment https://www.fordxr6turbo.com/forum/topic/86664-rda-vs-dbahow-much-difference-between-the-2-also-brembo-padsfg/page/6/#findComment-1525445 Share on other sites More sharing options...
