  • Too heavy needs boost
  • Member For: 11y 10m 20d
Fark the warranty I still had 3yrs 6 months and got board. Did most things and its farking awesome. Dont worry about the warranty because if you do it after your paying for it. So either way your paying for broken sh*t. Just do it and enjoy
  • 4 months later...
  • Member For: 11y 8m 11d
I removed the towbar and changed the white rear bumper insert to a new black one.
I've also bought an Earls Stealth Turbo Oil Line and Filter, so will hopefully fit that when I get a chance.
post-73588-0-52667500-1402305540_thumb.j
post-73588-0-26776400-1402305560_thumb.j
post-73588-0-31423000-1402305577_thumb.j
  • MattyP
  • Cruise Control
  • Member For: 13y 1m 22d
That kit is a biatch to fit I highly suggest getting your tuna/mechanic or at least have access to a hoist
  • 2 weeks later...
I took the car to Willowbank last night with the 19" wheels on around 38-40psi I ran 13.8 @ 107MPH, 2.3 60ft which was disappointing. But I think it was spinning a bit taking off. I just left it in "D" with trac off, didn't stall it up, just planted it straight away. My brother ran a 13.3 @ 107MPH, 2.3 60ft in his fg xr6t with stock 18s on 36psi, so I'm hoping I can get 13.1 to 13.2 on the stock wheels with a bit less tyre pressure and a good launch.
I only got 2 runs and on the first run I went "PD" but it hit the limiter really hard on the 2nd to 3rd shift so I backed off completely.
My brothers 2nd run he put it in "PD" and tried to stall it a bit but he also spun taking off and then his hit limiter going into 3rd also.
I've also bought an XR8 airbox and snorkel as well as a Rapid Systems 'intake muffler delete pipe'.
  • 2 weeks later...
I went back to Willowbank tonight and ran a 13.09 @ 109.8MPH this time so very happy with that. 60ft was 2.2
Only got 2 runs in though and the 2nd tramped very badly and limiter bashed 1st.
I'd really like to get it down to a 12.9 before getting tune & injectors.
  • Like 2
  • Member For: 17y 7m 1d
Massive improvement, you must be stoked with that!
Have you tried manually shifting?
