Guest Señor Deanodriver Guests Posted 24/01/04 10:53 AM Share Posted 24/01/04 10:53 AM with the standard diff and 5speed box, I'd say around 270.If it was modified purely for top speed (gearing, cams, etc), then 350+ could be possible.Wasn't the Raptor ute (or sedan, I forgot) trying to break some speed record? Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86007 Share on other sites More sharing options...
mickq Member 740 Member For: 22y 14d Posted 24/01/04 11:06 AM Share Posted 24/01/04 11:06 AM aps said: Hi Guys, Next week we are going to test the APS PHASE III for top speed, we have made a few small mods to gearing etc.,etc what speed do you guys think the T will run. And by the way what top speed have run in the T.PETERAPS It should be pretty easy to work out, yes?I think there is a not too tricky calculation you can do, based on power and also gearing ratios. You can even take into account the coefficient of drag if you want as at the higher speeds this plays a huge role in determining how many 100's of HP you need to get the final 20 odd kmh.I know there is a program on the net that will let you work all that out.It also calculates lots of things like optimum shifting points in each gear and best takeoff revs. Its not too shabby, and used by quite a few drag racers in the US.You enter a whole bunch of info...everything you can imagine.If I can dig up a copy for you, will you do a favour for me?What Id love is the info on a standard XR6T with 5 speed gearbox that is needed for the program.Including things like:- Gear ratios for each gear and the diff etc (may actually be on the Ford site or in the manual...will check)- Most importantly, power and torque for a bunch of different revs from idle to redline. I havent been able to get this data on my past cars as Ive never dynoed them. If you can help me gather the info on my stock manual car, then I can get the program working for me. Im sure much of that info you will either know, or have to find out if you choose to enter all the data into the program for one/some of your cars. Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86014 Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 2m Posted 24/01/04 11:22 AM Author Share Posted 24/01/04 11:22 AM Señor Deanodriver said: with the standard diff and 5speed box, I'd say around 270.If it was modified purely for top speed (gearing, cams, etc), then 350+ could be possible.Wasn't the Raptor ute (or sedan, I forgot) trying to break some speed record?I doubt that the xr6t would crack 250KPH at the stock power level with the speed limiter removed. You now have me thinking that this would be a worthwhile exercise, all need now is a stock 5 speed xr6t. Any volunteers?PETERAPS Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86017 Share on other sites More sharing options...
KrasH Bloody Orange Team (BOT) Donating Members 872 Member For: 21y 10m 14d Gender: Male Location: Canberra, Australia Posted 24/01/04 11:50 AM Share Posted 24/01/04 11:50 AM I read somewhere ( Wheels) that the cutof on the T is at 229km/h and that was at 4950rpm. Going by the rev limiter at 6000rpm, I would guess maybe a 245-250 in stock form with no speed limiter. For the Pahse III I will guess 275km/h. Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86019 Share on other sites More sharing options...
WBT56 Mal Wood Automotive Member 457 Member For: 22y 5m 29d Gender: Male Posted 24/01/04 11:54 AM Share Posted 24/01/04 11:54 AM aps said: ....What in your view is the wink link in the box?PETERAPS They are a good box, but under the application you are talking:A)Heat loading, they run VERY hot at load in fifth. General failure.B)Under extreme load in fifth, the separation force between the two gears is not supported and absorbed by a rear roller bearing like it is in a T56, TR3550 or Supra. The rear tapered cluster bearing acts as a ramp and converts this side load into end thrust, and this fries the front cluster bearing. Bang.C)High speed whip in the mainshaft causes the contact patch on the driven fifth gear to wander, chipping and eventually failing the teeth.D)Heat causes the tolerances to go out, and they rattle to death. Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86021 Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 4m 12d Posted 24/01/04 12:46 PM Share Posted 24/01/04 12:46 PM That means.......dont be weak, give it a go! Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86035 Share on other sites More sharing options...
hypnodoc It's All In Your Mind Gold Donating Members 2,198 Member For: 21y 6m 7d Gender: Male Location: Melbourne Posted 24/01/04 01:39 PM Share Posted 24/01/04 01:39 PM KrasH said: I read somewhere ( Wheels) that the cutof on the T is at 229km/h and that was at 4950rpm. Going by the rev limiter at 6000rpm, I would guess maybe a 245-250 in stock form with no speed limiter. For the Pahse III I will guess 275km/h. Trust me, when the speed limiter cuts in, the needle bounces flat out at 240 on the speedo. Rides a bit hairy though :banghead: Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86040 Share on other sites More sharing options...
Lumpen Poison Fish. Poison Fish. TASTY FISH!!! Donating Members 5,181 Member For: 22y 1m 21d Gender: Male Location: The Bogan Shire Posted 24/01/04 02:01 PM Share Posted 24/01/04 02:01 PM That program is called Cartest and I posted it on the forum ages ago...specsd and times seemed reasonable enough...maybe worth a look?PS-Grab the forums current one quick as the new version (different program, same programmer) is a pay for download..PS-Im thinking 282.... Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86059 Share on other sites More sharing options...
NT TURBO Member 1,128 Member For: 22y 1m 22d Gender: Male Location: Darwin NT Posted 24/01/04 10:29 PM Share Posted 24/01/04 10:29 PM Carn Peter the suspense is killing us! Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86097 Share on other sites More sharing options...
aps Member 1,505 Member For: 22y 2m Posted 25/01/04 04:30 AM Author Share Posted 25/01/04 04:30 AM NT TURBO said: Carn Peter the suspense is killing us!I promise I will let you all know when we have completed testing, the speed limiter removal is more difficult than I first thought,though I am sure we will get around the problem one way or another. PETERAPS Link to comment https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/page/5/#findComment-86171 Share on other sites More sharing options...
