  • Replies 52
  • SportCompact.biz
  • Member For: 22y 1m 20d
I would suggest 280km/h, I assume that you have removed the speed limiter? I also assume you are testing at a private venue :P
Edited by CnC
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85055
  • potty trained
  • Member For: 22y 6d
do we get to keep the T if we guess it right ?? ;)
hmmm .... ute or sedan ?? .... hmmm .... hit the wall at 285 would be my guess
(about 45 less if the speed limiter is still working :lol: )
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85057
  • Member For: 22y 1m 25d
Yeah, I think your pretty close to the mark,we are in the process of deleting the speed limiter not sure where the testing will take place.
PETER
APS
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85059
  • SportCompact.biz
I usually am :)
PS.. try avalon airport, or if that doesnt work, just wind er up down the princess highway on the way to geelong, its a very nice road for high speed testing, trust me on this.. :smilielol:
Edited by CnC
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85061
  • Member For: 21y 5m 6d
Hi Peter,
300 kph would put a smile on my dial - wouldn't you expect this from 385kw + ?
By the way, knowing you, APS wouldn't make any gearing mods unless they make the car go quicker. So, can you make these changes to my gearing when I fit the Phase III? Huh? Please?? :D
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85063
  • SportCompact.biz
The thing is, you can have as much power as you want, but at higher speeds coefficient of drag (wind resistance) has much more influence on the top speed than the amount of pwoer the car has.
As power increases the top speed will increase, but in a diminishing returns, almost logrithmic fashion..
Edited by CnC
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85068
Sedan with 5 speed man box I would be stoked if we can hit 285KPH, and you dont get to keep it if you guess right, though maybe a hairy drive on a quiet country road.
PETER
APS
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85069
  • Member For: 22y 5m 2d
hmmmm ummmm when I was ar in the northern territory I hit 240 and couldnt go past due to the limiter! I heard the limiter comes in at 230 but unless my speedo is out mine went to 240 no problem at all, so id say it should make 280 no prob.
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85073
  XR6_Turbo_Phase II said:
Hi Peter,
Would put a smile on my dial also,unfortunately we dont have sufficent gearing to hit the magical 300KPH. I think the 6 speed box with the good ratios would be the way to go to hit the 300KPH given theres enough power to push the gearing.
peter
APS
https://www.fordxr6turbo.com/forum/topic/8664-xr6t300kph/#findComment-85076
