turbotrana Member 2,586 Member For: 22y 1m 5d Gender: Male Posted 28/10/13 10:07 AM Share Posted 28/10/13 10:07 AM The FG turbo has the MAP sensor that is bolted to the manifold p/n AG9G9F479AA.It also has one that is on the plastic elbow leading into the throttle body.What does this one do?Does anyone have a part number for it as I rang both COVS and AMCAP and they just cant seem to find it on the computer. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/ Share on other sites More sharing options...
MattyP MattyP Cruise Control 6,317 Member For: 13y 1d Gender: Male Location: Central Coast Posted 22/01/17 02:20 AM Share Posted 22/01/17 02:20 AM Agreed! I wanna change mine as well Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1629257 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 12d Gender: Male Location: Perth Posted 22/01/17 06:31 AM Share Posted 22/01/17 06:31 AM Manifold mounted sensor is tmap. The other us boost pressure. Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1629271 Share on other sites More sharing options...
Frang New Member 5 Member For: 7y 7m 10d Posted 25/09/17 12:05 PM Share Posted 25/09/17 12:05 PM Hi Does anyone have a photo of where this is on the inlet manifold ? I've been googling and can't find a picture of an XR6 Turbo I've had the MIL light come on for over 6 months now and after replacing both oxygen sensors I'm going to change the MAP sensor. I have the P023D "Powertrain" code which seems to point to the MAP sensor. After calling supercheap they said there were about 4 of them. I've ordered one off ebay that's for the inlet manifold as I'm assuming its the important one. I'm wondering if its easy enough to change without having to unbolt everything, or if its better to have a mechanic change it ? Thanks for any advice. Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1645161 Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 29,472 Member For: 17y 25d Gender: Male Location: Melbourne Posted 25/09/17 12:28 PM Share Posted 25/09/17 12:28 PM here's the T-MAP sensor. It's easy to change on an FG. Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1645162 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 12d Gender: Male Location: Perth Posted 25/09/17 11:26 PM Share Posted 25/09/17 11:26 PM On 25/09/2017 at 12:05 PM, Frang said: Hi Does anyone have a photo of where this is on the inlet manifold ? I've been googling and can't find a picture of an XR6 Turbo I've had the MIL light come on for over 6 months now and after replacing both oxygen sensors I'm going to change the MAP sensor. I have the P023D "Powertrain" code which seems to point to the MAP sensor. After calling supercheap they said there were about 4 of them. I've ordered one off ebay that's for the inlet manifold as I'm assuming its the important one. I'm wondering if its easy enough to change without having to unbolt everything, or if its better to have a mechanic change it ? Thanks for any advice. Expand Very unlikely it's the TMAP at fault Has the car been tuned/fiddled with? Also the pic posted above is a non turbo TMAP sensor location. Turbo require removal of intake piping and throttle body to access the sensor. Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1645164 Share on other sites More sharing options...
Frang New Member 5 Member For: 7y 7m 10d Posted 26/09/17 10:27 PM Share Posted 26/09/17 10:27 PM Thanks for the advice. I changed it this morning. I only had to remove the pod filter to get enough hand room. I have no idea what has been done to car, I bought it in January from Gumtree (car dealer in WA) and had it freighted to NSW. I know the air intake has been changed, otherwise I have no idea. I'll test it out for a couple of weeks and if the light comes back on I will probably be asking for more advice Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1645188 Share on other sites More sharing options...
Chrisooo97 New Member 11 Member For: 7y 3m 22d Posted 13/01/18 12:45 PM Share Posted 13/01/18 12:45 PM What was the code that was coming up when it was scanned for the check engine light ? Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1650757 Share on other sites More sharing options...
Puffwagon Puff Gold Donating Members 16,337 Member For: 10y 3m 6d Gender: Male Location: South Australia Posted 13/01/18 12:51 PM Share Posted 13/01/18 12:51 PM Man you're going to have to notify them somehow otherwise you won't get an answer. The best way to do this is to use the @ symbol then type their username without a space like this @Chrisooo97 Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1650758 Share on other sites More sharing options...
Chrisooo97 New Member 11 Member For: 7y 3m 22d Posted 13/01/18 12:55 PM Share Posted 13/01/18 12:55 PM Oh cheers I'm new to this haha @Puffwagon Link to comment https://www.fordxr6turbo.com/forum/topic/86637-fg-map-sensors/#findComment-1650759 Share on other sites More sharing options...
