  • 2 years later...
  • Member For: 13y 2m 13d
2010 FG turbo Auto ,  running 1000cc KPM injectors with twin pump KPM intank setup , but running standard fuel regulator , since tuned car not all the time will drop below 500rpm & sometimes stalls , tuner has told me need to upload the file tune to compersate for injector scaling to be right . Car currently running on Efex
  • Member For: 22y 1m 3d
You running twin pump and standard reg. You need high flow reg, contact KPM and put it in. Get a fuel pressure gauge and check to see where pressure is at. Got to make sure mechanical side of things is done properly before tuning.
And for those that have stalling cars, your tuner simply does not know what he is doing. Have seen enough cars, the mods and the tunes to come to the conclusion some of these tuners are a bit thick or lazy. You should expect a rock solid return to idle, no excuses.
Edited by turbotrana
