HSV-H8R Member 7 Member For: 11y 1m 22d Posted 23/10/13 08:59 AM Share Posted 23/10/13 08:59 AM hi guys/girlsNot sure if this is the right area for this but in need of some help..have only had car roughly 2 monthsa couple of weeks ago I was driving along coming up to my drive way and changed back gears to slow down and the car just stalled(very dangerous as power steering etc was all gone) and struggled to start again unless I kept the revs on her..I thought it may have been the battery as I've heard some weird things happening to the fords when have low voltage such as alarm going off by itself (and as I had a computer hooked up to it to find another fault and low voltage was one of them).so I changed the battery (with second hand slightly smaller one) and all was fine, then bout a week later coming up to an intersection and it stalled again, started it and stalled straight away. tried a 3rd time and and kept revs on and was fine up until today.so before it happened today I went and brought a new battery as the one in it wasn't quiet big enough.. have just changed it now and thought I would let it run for a bit just to charge up the battery for a little bit and after about 5-10 mins after running fine it stalls.. tried starting again and just stalls.. tried couple of times kept stalling, started it and kept revs on stayed on but as soon as u let the throttle off it stalls. this kept on for a bit then I turned key fully off and tried 30 seconds later and it didn't do it again..has this ever happened to any one else or does any one have any information for me, as I am a bit sketchy to drive anywhere at the moment as if it stalls while driving along at say 100 kms, its not real safe..help much appreciatedCheersLeigh Link to comment Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 6m 29d Gender: Male Location: WA Posted 23/10/13 10:08 PM Share Posted 23/10/13 10:08 PM (edited) How many km's on the car? If its a few and there is no oil catch can plumbed in between to PVC valve and intake the butterfly in the throttle body. When slowing down using engine braking the vacuum in the intake becomes very high and it will pull your butterfly closed causing it to stick there on the burnt oil ( from the PVC ). You can test this by slowing down with your brakes and not your gears. A bit of throttle body cleaner does the trick. Don't worry to much. You can still steer the car when stalled at 100kmhr. Although I doubt that will happen with your problem. Edited 23/10/13 10:11 PM by AdamIan69 Link to comment Share on other sites More sharing options...
HSV-H8R Member 7 Member For: 11y 1m 22d Posted 23/10/13 11:44 PM Author Share Posted 23/10/13 11:44 PM it has 193000 kms.. ive just done an oil change on it but was doing it before that.. so the same thing is happening when just sitting there on idle and it turns off by itself straight after start up???also how too prove this when it does'nt do it all the timeits had tune and different valve springs from previous owner would this affect any of this??I have also just put a turbosmart dual port bov on, this wouldnt be causing any issues would it??cheers Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 3m Gender: Male Location: Zombie Birdhouse Posted 24/10/13 12:01 AM Share Posted 24/10/13 12:01 AM with that number of Ks I'd start with a throttle body clean.Could well be your issue. Let us know how you go Link to comment Share on other sites More sharing options...
HSV-H8R Member 7 Member For: 11y 1m 22d Posted 24/10/13 06:17 AM Author Share Posted 24/10/13 06:17 AM will do mate,a mate is coming over tomorrow with some cleaner, will keep posted Link to comment Share on other sites More sharing options...
rockafellqeinstien Member 325 Member For: 16y 3m 27d Posted 24/10/13 11:18 PM Share Posted 24/10/13 11:18 PM clean throttle body and look for vacuum leak on intake piping (pressure test and soap suds) Link to comment Share on other sites More sharing options...
