  • Member For: 12y 5m 7d
I am after some advice to see if this will work I have recently upgraded to a new cooler system with plamaman pipework that now goes down under passenger headlight and the blow off valve is located behind the passenger headlight.my question is could I run a 90 degree silicon fitting and run it down under the headlight so it can not be seen but it will be roughly 6-8 inches away from the fitting in the pipework .will the blow off valve still work as it would if it was just on the cooler pipe .
I would like to hide the blow off valve so it cant be seen by police my last set up my blow off valve was hidden inside my plazmaman airbox and when got pulled over never had a issue (cop told me first thing they look for is blow off valve ) and if he cant see it its better
any help will be great as I dont want to plumb it back to intake on the other side of engine bay
