when I had a leak on my throttle body gasket it would hold almost 2k rpm when idling - initially it wasa random but became permanent.
pressure test of intake found it and new gasket for $5 fixed it.
  • Member For: 12y 9m 6d
mate, I would get it looked at asap, as this sounds really dagerous....could be a number of things
_stuck pedal?
-pedal sensor
-throttle body
-big vacume leak??
before you end up in a tree (as said) or similar...
  • Member For: 14y 7m 24d
  On 23/10/2013 at 5:12 AM, -SteveR- said:
That sounds pretty scary, what if it decides to floor it all of a sudden?
Should get it to a mechanic that knows his Fords. Might put you into a tree otherwise.
This was 2 yrs ago in my old BA MKII I have a FG G6ET know. I did take it to 2 forum sponsors in Sydney and they couldn't fault it and I had it for another 12 months and never did it again... I know the new owner and its never done it to him either.... It was 2 days after putting it all back to stock after having it tunes with injectors, intercooler, cat etc.
  • Member For: 17y 5m 5d
  • Member For: 11y 7m 1d
hi,
I had just experienced same problem.. mine was stalling a couple of times over past few weeks and after a throttle body clean it has seemed to have stopped that and now just coming up my street to home I backed of to slow down and it kept accelerating.. put clutch in and sitting about 2200 revs.. gave it a rev and still sat at 2200.. drove into yard and reved a couple of times and dropped down but when revving it would stay up around 2000-2200 for couple of seconds before dropping down.. turned off and back on and didn't do it again..
maybe time for new tps???
is there a life spane for the actuale throttle body? I know they can f*ck up but is there a service time when you should replace them?
I seen them on ebay for about 200 genuine
