ausfalcon Member 3 Member For: 11y 6m 11d Posted 21/10/13 10:19 AM Share Posted 21/10/13 10:19 AM Good evening. Hope this is the right place to put this post..I have an XR6 Turbo BA 2On a couple of occasions it has stalled. Once re started the revs hold at between 2000 to 3000 rpm at idle or even when on the M2 I didn't have to use accelerator! it just pulled along at those revs! Problem was it kept those revs at traffic lights or in slow traffic..Once turned off and re started problem went away. This has happened twice one 6 months ago and once yesterday.I disconnected battery any way to reset ecu.. not sure if that does anythingAnyway thanks for reading Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/ Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 7d Gender: Male Location: Probably above atmospheric pressure Posted 21/10/13 12:35 PM Share Posted 21/10/13 12:35 PM (edited) Throttle Position Sensor?Throttle body? Edited 21/10/13 12:36 PM by -SteveR- Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435013 Share on other sites More sharing options...
ausfalcon Member 3 Member For: 11y 6m 11d Posted 22/10/13 09:23 AM Author Share Posted 22/10/13 09:23 AM Thanks for reply.I will check those items Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435231 Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 7m 27d Gender: Male Location: Penrith Posted 22/10/13 09:51 AM Share Posted 22/10/13 09:51 AM (edited) had the same issue with my old BA MKII, but only did it once, had codes checked by my mechanic it came up running rich something cannot remember, he also thought TPS, but it never did it again so never followed through. Edited 22/10/13 09:51 AM by gsd112 Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435241 Share on other sites More sharing options...
ausfalcon Member 3 Member For: 11y 6m 11d Posted 22/10/13 11:50 AM Author Share Posted 22/10/13 11:50 AM I have only had this happen only twice in the last year. It stalls then revs like crazy. Then turn it off and its as good as gold once started again.I wont worry until it becomes more of a problem! After 175k things cant always be perfect..Thanks for your info. Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435279 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 7d Gender: Male Location: Probably above atmospheric pressure Posted 22/10/13 01:12 PM Share Posted 22/10/13 01:12 PM Maybe take off the crossover and turn key on a click to get power, see if the butterfly moves smoothly according to pedal input.I can't recall 100% but I think the trick of holding the throttle FLAT and turning the car over (it won't start) is the reset for the TPS, won't help if the unit is buggered of course. Not sure how long you need to crank it for, I'll see if I can find out. Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435291 Share on other sites More sharing options...
jas98 Member 1,046 Member For: 12y 9m 9d Gender: Male Location: Maryborough Qld Posted 22/10/13 02:14 PM Share Posted 22/10/13 02:14 PM yeah to reset TPS its a turn key to reds then hold pedale to floor for 10 seconds. was told this by 2 ford dealers....they said do not try and crank it as it wont reset?......did nothing with mone though haha Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435298 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 7d Gender: Male Location: Probably above atmospheric pressure Posted 22/10/13 03:07 PM Share Posted 22/10/13 03:07 PM (edited) Ah there ya go then, cranking is not to be done. From reading a few bits of my manual I found it's for clearing a flooded engine Quote To assist in clearing a flooded condition, the PCMdisables the fuel injectors if the throttle is held wideopen during Crank mode. It is possible this mayintroduce a DTC, P1124. If this is the case clear theDTC and proceed with a KOEO and a KOER test. Edited 22/10/13 03:08 PM by -SteveR- Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435304 Share on other sites More sharing options...
gsd112 Donating Members 604 Member For: 14y 7m 27d Gender: Male Location: Penrith Posted 23/10/13 04:29 AM Share Posted 23/10/13 04:29 AM Mine didn't stall drove 30mins stopped for 20mins started car and it was reving at 2500rpm, drove off got on the freeway and was sitting on 120 without touching the accelerator, pulled over turned off turned back on and it was fine Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435408 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 7d Gender: Male Location: Probably above atmospheric pressure Posted 23/10/13 05:12 AM Share Posted 23/10/13 05:12 AM That sounds pretty scary, what if it decides to floor it all of a sudden?Should get it to a mechanic that knows his Fords. Might put you into a tree otherwise. Link to comment https://www.fordxr6turbo.com/forum/topic/86567-xr6-turbo-over-rev/#findComment-1435414 Share on other sites More sharing options...
