  • 2 years later...
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 5d
Probably PM the bloke over on AFF?
But the consensus is that the IMS diff setup replacement is the way to go, these days.
  • Dropping a turd
  • Member For: 17y 5m 19d
You don't necessarily need a CAT bolt, a good quality grade 12.9 will be fine, that's what the CAT bolt is. Greater tensile strength with greater fatigue resistance. Stock is grade 10.9.
  • Puff
  • Member For: 10y 2m 17d
I'm pretty sure Arron already did that. I recall reading a thread where the exact specs were spelled out but I could be wrong. Hit up the search bar if you're keen.
If you're at the point where you are snapping diff bolts then you should replace the hat like hamster nuts said. Haha that or adjust your driving. :3gears:
  • Dropping a turd
  On 19/08/2018 at 12:32 AM, MenaceXR6 said:
I just need someone to suggest a good bolt to buy with the correct specs
Expand
Read the whole thread, has good information. Install the same length bolt that comes out, or  if you are really keen measure thread depth and make it a bit longer.
How many have you snapped and did they fatigue? This is mine. You need VERY firm front bushes to help with the bending. Bending causes fatigue cracks to initiate.
Edited by arronm
  • New Member
  • Member For: 8y 11m 3d
I have an N/A BF XR6, ZF 6 speed with 211rwkw and 500nm, im not running enough power to snap them all the time, I also have Nolathane solid bushes front and rear, thinking about changing the rear to something a bit softer to take a bit of load off the single bolt, I snapped an original one I re-used alot of times, it originally was quiet, but it started clunking for months after a few weeks, then snapped while doing u-turn extremely slow, I put a spare one I had in and it was quiet, now its started clunking again and I feel the same thing will happen, so I want to try a brand new bolt, I dont believe it SHOULD snap, but before I do anything major, a new bolt is worth a try, I cant find the correct bolt on the CAT website and with how strong they are rated and how annoying removing the cradle is for the 50th time, I just want to try it
