How To Tell If Timing Skipped?
jas98
  • Member For: 12y 4m 29d
Hi, how do I tell if my timing on a ba xr6t has skipped a tooth or 2, cars running fine, just at idle it has a miss but only when air cons off...
replaced (did before and after):
coils
plugs
TPS
oil temp sensor
head temp sensor
O2 sensor
intake gaskets
turbo gaskets
cleaned throttle body
air cleaner
changed injectors
Fuel pressure regulator
fuel filter
engin mounts (one was fueked!!)
and few other things icannot remeber
cheked codes
all theabove made the car drive beautifully its just this annoying miss it has lol.
so sthere a way of useing ets say...ageneric scanner t see if its skipped a tooth or would I feel it all the time if it has?
also "if" for sum reason teh waste gate is not closeing fully when at idle can that cause it??
Edited by jas98
  • 9 months later...
  • Member For: 17y 27d
Wow slow response to poor old OP. He asked in October 2013 though I'm sure jas98 is still around here
Yep that's how I fixed it hahaha.
