munyac5 Member 28 Member For: 11y 6m 20d Posted 09/10/13 04:17 AM Share Posted 09/10/13 04:17 AM Have a 07 BF MK2 - Auto Car is currently making just under 290rwkw. Car has the following:Stage 3 Nizpro CoolerPW under battery CAIPW Cross overSiemens 60lb InjectorsWalbro in tank pumpCappa custom tune at Pulse Racing What I’m thinking of doing to chase 350rwkw...Port TurboGet Turbosmart 12psi actuator and flapper mod from Cappa4 inch dump, 3inch hi flow car and twin 2.5Xcal3 and Custom Tune. Would there be anything else I need to get? Or would there be another way in getting these figures?I drive it everyday, a good 60-70km so need it to be reliable. Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/ Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 6m 17d Gender: Male Posted 09/10/13 04:19 AM Share Posted 09/10/13 04:19 AM Chuck a hi flow cat in it and it will comes close. Your mods are enough Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431590 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 4m 21d Gender: Male Location: Probably above atmospheric pressure Posted 09/10/13 05:04 AM Share Posted 09/10/13 05:04 AM Agree, my BFII auto is 325rwkw and held back by injectors (42lb) but has full Manta 2x2.5" exhaust which I think has 3.5" dump. Also nizpro cooler with piping to stock crossover, and intank pump. Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431610 Share on other sites More sharing options...
munyac5 Member 28 Member For: 11y 6m 20d Posted 09/10/13 07:08 AM Author Share Posted 09/10/13 07:08 AM Thanks,Would there be anything I need to worry about and would I be able to reach this running 14psi? Just want to do it without blowing anything. Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431626 Share on other sites More sharing options...
MarksToxicXR6t Member 48 Member For: 11y 6m 26d Gender: Male Location: victoria Posted 09/10/13 07:23 AM Share Posted 09/10/13 07:23 AM If you have a stock exhaust definitely get that done the stock ford cat restricts a lot of flow, get a a high flow cat with ya exhaust and a retune and u should b lookin around those numbers with the mods ya already got and if ya want to run higher boost get ya valve springs done I run my xr on 10 psi day in day out and it's safe!!!!! Plazaman heavy duty valve springs are good that's what I run in mine!!!!!! Hope this helps Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431628 Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 8m 8d Gender: Male Location: Adelaide Posted 09/10/13 07:24 AM Share Posted 09/10/13 07:24 AM Valve springs maybe Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431629 Share on other sites More sharing options...
munyac5 Member 28 Member For: 11y 6m 20d Posted 09/10/13 09:57 AM Author Share Posted 09/10/13 09:57 AM Ill make sure I get a set.I was thinking either plaza or atomic HD.So no need for the actuator n flapper kit nor the porting of the turbo?Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431674 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 17d Gender: Male Location: Canning Vale, W.A Posted 09/10/13 10:42 AM Share Posted 09/10/13 10:42 AM (edited) Valve springs and youll see more then 350Yeah 100% do Edited 09/10/13 10:43 AM by turboboink Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431686 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 18d Gender: Male Location: @ my laptop Posted 09/10/13 11:24 AM Share Posted 09/10/13 11:24 AM you need the turbo work Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431695 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 14d Gender: Male Location: Adelaide Posted 09/10/13 11:46 AM Share Posted 09/10/13 11:46 AM Why are u getting cappa to do the flapper mod, u in the riverland ? Link to comment https://www.fordxr6turbo.com/forum/topic/86469-so-im-chasing-350rwkwwill-this-do/#findComment-1431704 Share on other sites More sharing options...
