Lowest Coilovers
KEBAB_DRIFTER
  • Member For: 13y 10m 7d
Hi guys just purchased a G6E Turbo and im chasing a set of coil overs that go really low , ive seen a pic of XYZ coils that seems to be pretty low but pic was taken from above
will I have to remove the rear adjusters to get the desired rear height?
Can anyone recommend a brand that will go low but retain a softer spring rate eg... 10kg?
Yes I understand the logic of why would I want to go that low on a g6 , coming from a skyline that was 50mm off the ground I think ill cope plus airbag sus isn't a bolt in option
XYZ , PEDDERS , KSPORT , OZ racing, a mod on here had some COILS he was making , others?
Cheers Mick
  • Expert
  • Member For: 19y 10m 27d
give Pat a call from wholesale Suspension his the go to man mate.
Forum Link
http://www.fordxr6turbo.com/forum/forum/180-wholesale-suspension/
Wholesale Suspension Website
http://www.wholesalesuspension.com.au/
Forum Link
Cheers Angel
XYZ are the lowest I've seen.
Yes cheers , It seems all the fronts seem to go low enough its the rears im thinking about , how does the rear spring height vary over the different brands
oh dear.
Your problem?
  • Member For: 14y 3m 4d
Well I run 4sl rear king springs with a hub to guard of 320mm and my mates xyz's go lower than that. If you every want to go lower than that you'll need bags. And I know you said you don't want bags but if you want to go crazy low might aswell
  • Carnage on the Garage Floor
  • Member For: 14y 8m 12d
You all know that it fks the geometry and handling of the car not to mention roots the cv's yes? As long as looks slammed I guess, lol.
I'm just old :)
Edited by Bomber
