Actuator Bolt
Banjora07
  • Member For: 15y 9m 21d
You can do it on the car fairly easily. You need a hooked pick, a mechanics mirror and a torch. Very fiddly, but easy. Remove rear heat shield, use. Mirror and torch to locate circlip, that holds on actuator rod to wastegate flap and hook it and pull. Wind on a few threads and replace circlip. Easy. Just requires a bit of patience.
  • in the mid....not the bum like some
  • Member For: 11y 8m 30d
A very long pair of pointy end pliers can be used to turn the threaded rod into the actuator arm if its not seized and easy to turn.
Saves pulling the e-clip off etc worth a try.
