Banjora07 Member 66 Member For: 13y 2m 19d Posted 04/10/13 11:47 AM Share Posted 04/10/13 11:47 AM Hi just got new 12 psi actuator and flapper mod but up in high top the boost feels a bit jerky and was told by tuner I need to tighten actuator bolt can I do this without taking the turbo off any help would be great thanks Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 5m 27d Gender: Male Location: Adelaide Posted 04/10/13 11:58 AM Share Posted 04/10/13 11:58 AM Was it on when you had the tune done or after Link to comment Share on other sites More sharing options...
Banjora07 Member 66 Member For: 13y 2m 19d Posted 04/10/13 12:07 PM Author Share Posted 04/10/13 12:07 PM Nah before tune he just said tighten it a bit more and it come on harder and stop boost jerking around in high rpm Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 4m 5d Gender: Male Posted 04/10/13 12:35 PM Share Posted 04/10/13 12:35 PM Boost control is in the tune Link to comment Share on other sites More sharing options...
fehlbie Donating Members 142 Member For: 15y 10m 1d Posted 04/10/13 12:46 PM Share Posted 04/10/13 12:46 PM He means shorten the actuator rod by tightening or winding on more threads. This increases the preload on the actuator. Link to comment Share on other sites More sharing options...
Bizkets is Drunk? Too heavy needs boost Member 5,929 Member For: 11y 5m 27d Gender: Male Location: Adelaide Posted 04/10/13 12:56 PM Share Posted 04/10/13 12:56 PM Shouldn't he have done that to help you get the cleaner boost and the results you were looking for. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 5d Gender: Male Location: @ my laptop Posted 05/10/13 02:12 AM Share Posted 05/10/13 02:12 AM No, not normally part of the tune cost.if the tuner fitted the actuator a different story but I the owner did it themselves or had somebody else do it, it's not the tuners issue to rectify somebody else's work, saying that, it should not be jerky and that may be in the tune which the tuner should sort out Link to comment Share on other sites More sharing options...
Banjora07 Member 66 Member For: 13y 2m 19d Posted 05/10/13 04:31 AM Author Share Posted 05/10/13 04:31 AM But can you tighten the bolt with the turbo still on or do I have to pull the turbo off? Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 12d Posted 05/10/13 04:47 AM Share Posted 05/10/13 04:47 AM Yeh I believe you can but it's a bitch of a job. How much preload did it have when u fitted it? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 5d Gender: Male Location: @ my laptop Posted 05/10/13 05:47 AM Share Posted 05/10/13 05:47 AM depending on your mechanical aptitude, they can be adjusted on the car, but most people would be easier to remove the turbo, adjusting it is not going to fix your problem if it's jerking Link to comment Share on other sites More sharing options...
