  • Member For: 16y 9m 13d
Hi Guys - been getting a strange noise from what I think is the turbo. First time it happened I shat myself because I was giving it a bootful on a freeway on ramp and it sounded like a police siren! I thought it might be the BOV because it happened when I was backing off the loud pedal. It doesn't happen all the time and the car is otherwise running normally and boostin well. Today it happened under about 75% throttle. I backed off and then gave it a bootful but it didn't repeat the sound.
Car has done 175K kms
https://www.fordxr6turbo.com/forum/topic/86422-weird-intermittent-turbo-noise/
What are bearing harmonics? The reason I was thinking BOV is because it sort of sounds like the whirring/whining whooshing noise you hear from ricer cars when they are changing gears. I sh*t you not though - I could have sworn it was a cop siren in the distance behind me when it first happened!!
  • Member For: 12y 2m 4d
under heavy vibration (bearing failing) at certain rpm they can make emit a high pitch ringing sound but I dont think it would be that loud
  On 05/10/2013 at 1:40 AM, johnxr6t said:
Does it have a noise when turn motor off?
No noise when engine is turned off.
Boost leak is a possibility but surely it would howl every time it boosted? Same with bent fin or bearing problems...
I don't know enough about bovs to be sure but can they get stuck - ie not open enough and create different noises?
  • 2 weeks later...
Well, it's been a couple of weeks and the noise hasn't repeated once. Is it possible there was a temporary obstruction in the BOV?
