Photo Essay - Bf Falcon Driver Seat Belt Replacement
PhilMeUp
  • Member For: 16y 8m 12d
The driver’s seat belt in my taxi has been due for replacement for a while. I went looking on the internet and through some service manuals for a guide on how to pull the plastics off but couldn’t find anything.
I figured “stuff it” - I’ll have a go, and if I break the plastics then I’ll replace them. It turned out that I managed to guess right.
This is common - the seat belt frays over time. When it’s only minor you can cut the frayed parts off with a sharp knife, or melt them away with a cigarette lighter, but sooner or later you are going to have to replace the seat belt.
This is the bit that had me stumped at first - it turns out that you just poke your fingertips in behind the plastic and pull it out. There are two clips behind the plastic that attach it to the car.
These are the two clips on the other side of the plastic.
Where the clips clip into on the car pillar. Very simple stuff.
At the bottom of the top pillar plastic there are these two tabs, which go into the bottom plastic. Be careful not to break these when you are removing the top plastic.
Once you’ve got the top plastic loose then you remove these two screws, which help to hold the bottom plastic in place.
I can’t remember when and where I bought these from, but they have proven to be very useful. Teng Torx socket set. I’ll be using the T50 for this job.
Once the plastics are removed it’s time to start removing the actual seat belt. Do NOT touch the silver bolt in the middle - that’s part of the seat belt and gets replaced with the new belt. The bolt to remove is the top black one, which requires a 10mm socket.
At the bottom of the seat belt the bolt is covered by this plastic cover. I removed this easily by levering it off with a flat blade screwdriver. When you do this, do it gently so that the plastic cover doesn’t fly off to somewhere where you can’t find it.
Once the plastic cover is removed there is this T50 bolt.
A photo of the new seat belt, which also includes the upper mechanism. As you can see, the Torx bolt that I mentioned earlier to not loosen is part of the new belt.
Once you have removed the old seat belt there will be this bracket. Mine fell out just after I took this photo so it was handy to check on the camera which way it goes back on. There are two small prongs that go into the hole to hold the bracket in place, and I then bent them out a little bit so that the bracket would stay there while I put the new seat belt into place.
Once I had the plastics out I figured it was time to clean them. Off to the laundry I went.
I tried a couple of things, but this is the stuff that I ended up using. You can buy these aerosol eucalyptus oil spray cans from most large supermarkets and chemists. This stuff is extremely useful for cleaning anything plastic. You can see the clean streaks on the left of the photo - that’s where I sprayed the stuff on and wiped my finger over it - it took a few seconds for the eucalyptus oil spray to soak in, but once it did the grime came off easily.
Thanks to the eucalyptus oil the plastics ended up looking a lot cleaner.
Now it was time to get back to the car. At the bottom of the seat belt, the belt roll is held in with this T50 Torx bolt. Removing it was easy enough, but it was a bit fiddly getting the bolt to line up with the new belt roll.
The upper mechanism is held in place just by the one bolt at the top. At the bottom there are two hooks - you put the mechanism into place and slide it upward a little bit until the bolt hole lines up with the thread in the car pillar. Then put the bolt back in.
By now it was all coming together. This is when I remembered that I feed the seat belt through the top plastic, before putting the bottom seat belt bolt back in.
Once the bottom bolt was back in, it was time to get the plastics back into place. The bottom plastic was easy enough. With the top plastic, you have to make sure that it lines up correctly - that circular shaped bit in the middle goes over the silver bolt on the seat belt. You have get this lined up to get the top plastic back on correctly.
This is the bolt that the circular bit goes over. Not hard to do, but essential.
I had to slide the adjuster guide up and down a bit to get things to line up, but it wasn’t difficult to do.
The completed job. Everything is bolted into place, and I’ve put the plastics back in. Note that the door seal rubbers go on the outside of the plastics in all places. There were areas where the rubbers ended up on the inside of the plastics, which I sorted out with a combination of fingertips and poking a flat blade screwdriver in there and rolling it along to feed the rubber back out.
There was an instruction guide in the box with the new belt, which I found to be quite useless - it didn’t cover how to remove the plastics.
I’ve kept the old seat belt for now - I’ll look into getting it re-webbed for next time (ie just the belt part replaced). That way I’ll have a spare sitting at home, ready to go. If re-webbing is cheap enough then I’ll do it at least a couple of times a year - I like having a seat belt that retracts easily.
Great write up have to save this for when I have to do mine down the line.:D
I did the same job two years ago but couldn't remember how to get the top plastic off.
You won't be the only one referring back to this in the future... :happy114:
  • Member For: 17y 4m 4d
Had a wrestle with this when I fitted my fire extinguisher to my car before Racewars (seat out job). I also got caught with the failing to thread the belt through the plastic before reattaching the bolt :)
I didn't have eucalyptus spray so I used the next best thing...
Also thinking of cleaning mine as it's slow to retract (yellow sticker material). That or ebay have a new unit for $175. No frays in mine...but my plastic has the same grooves worn out of it at my previous seat belt heights!
Edited by -SteveR-
  • Like 2
Been there, done that... they retract slowly when they get dirty.
I had that a few months ago. Apparently the way to go is to clean it with a steam cleaner.
I ended up going to a car wash, pulling the belt out and closing the car door (with the belt outside the car).
Use the high pressure water on both sides of the belt. Drove home and left the belt extended out for an hour (fed it through the steering wheel).
Left the car idling for an hour with the heater on full, and the belt was then dry.
Full on! Damn. If anyone knows a cleaning product that works let us all know.
