  • skids
  • Member For: 12y 5m 12d
  • Gender: Not Telling
It's really all about how the cars driven, I've broken a few things under stock power. It's had a lot of front end work done recently but the rear end is juuuust about to be looked at and I'm suspecting it's alot more than just a diff bush as I looked at mine and it still looks quite new and tight (but I've heard they can look good but be f*cked?)
If you guys think something is unbreakable in your turbo falcon, I suggest you let me have a drive, I'll either crash cause I still think stock power is pretty fast or break something.
Edited by johnxr6t
  • Waiting for the 1st N/A 12!
  • Member For: 17y 3m 29d
330 engine
400 ZF input shaft
440 ZF input shaft
440 ZF input shaft
440 Left side engine mount
500 Centre bearing tail shaft
525 Right CV shaft
Probably more but can;t think.... a few sets of diff bushes as well.
  • loitering with intent
  • Member For: 21y 9m 21d
Way back when. Running stock 185 rwkw then tuned ( unichimp, pre edit) 260 rwkw
Had the dubious honor of being one of the first to bugger the CVs, near Broadmeadows returning to Sydney.
Made it Albury and just farked. Parts requested to be sent to Melbourne for analysis.
Fixed under warranty. That is before people strated modding seriosly
Add clutch in Phoon 1 @ 300 rwkw ( dealer abuse)
and of course diff bushes on Phoon 2
Edited by Buf-Phoon
Yep had mega lean tune in it and didn't like 250kms per hour at wot with full car and luggage and in the middle of Australia!
  • Like 2
  • Member For: 14y 7m 21d
Pretty sure my zf is starting to flare. Only does it when cold does that sound right?
Running 290rwkw for 3 months and about 3000kms. Flushed gearbox with Syntrans and add trans cooler before tune so maybe the gearbox doesn't like oil not up to temp
  • Member For: 12y 5m 8d
361 kw .. Timing chain started to rattle so replaced that and done oil pump gears
361 kw .. Valve spring snapped,dropped valve, smashed a piston .... Fixxed that along with exhaust leak
Retuned to 350kw :)
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 2m 12d
340rwkw for 110k's (bought brand new) snapped chain, dropped valve fixed. And tuned to 352rwkw
Rebuilt gearbox after 80k and reconditioned turbo @ 100k
