  • Member For: 12y 9m 8d
Looking to find out how much power people were making and what components they broke at that power....
trying to establish a trend of broken bits and power levels. not really looking for one offs.
common power related component breakages..
what have you got?
I'm at 387rwkw and have nothing to note....
although the clutch flares in 5th on boost trying to overtake trucks on the highway... but that's to be expected.
Planning springs, boost and oil pump gears.
cheers
  • Member For: 12y 10m 11d
when you change gears in a auto (upwards) it selects a longer ratio, therefore the engine speed will drop to match this ratio. when changing, if the engine rpm stumbled and keeps climbing, then changes, that is flare. its when the gearbox cannot clamp the gears strong enough to transmit the engine power/rpms
o and back on topic, I own a 02 ba xr6t and so far its just been throttle bodies and clutches at 320rwkw and 360rwkw. Putting ultra-lows in the back on Monday so ill soon add driveshafts in this section lol
Clutch Flare..... or "clutch burnouts".... ever seen someone in a manual go to drop a skid and the wheels dont spin, then you get an awful smell and some light smoke from under the car..
Its just the pressure plate not being able to apply enough force to the friction plate to clamp it hard enough against the flywheel, to give drive through to the gearbox and driveline, so it spins on itself.
Prolonged or excessive flare can cause the friction plate to glaze or polish and then it will lose efficiency, leading to premature failure.
  • Member For: 19y 3m 27d
except wagnman has auto
380rwkw 110000k's (been over 290rwkw since 55000k's) and I haven't broken anything yet.
I am pretty big on preventative maintenance though
  • Will do skids for food
  • Member For: 13y 7m 5d
400rwkw stretched the bolt holes on the stock flex plate pretty quickly.
Nizpro one with ARP bolts now in place.
Powercruise next weekend, fingers crossed for no problems.
I was quoting on my experience
