Xr6 Turbo P_Ba_Xr6
P_BA_XR6
  • Member For: 16y 8m 5d
Yes It has same comp wheel but as you can see the car was making 391 at 18 and now Makes 405 at 16 all I have done to turbo change front housing. Reason being I did rebuild the turbo not long ago so wasn't ready to get new one ". This was before I "even thought about the 400 mark
But probably does help I have also top mounted with tuned length manifold and external wasgate
  • Member For: 16y 10m 18d
Christians 9.9 was stock turbo with .7 cover, about 450rwkw.
  • in the mid....not the bum like some
  • Member For: 11y 9m 14d
It may suck a larger volume of air but it will be at a slower speed.
.50 cover every day of the week with the 3540....loose 20hp max but gain better torque curve and that will toast the 20hp not there up top from the .70 cover.
Standard hot side pipe is the go as well if you want the boost in as quick as possible.
Larger volume of air may not always beat something with a tiny bit smaller volume but more air speed.
