XR-MAKO New Member 18 Member For: 16y 8m 28d Gender: Male Location: Sydney Posted 24/09/13 01:01 AM Share Posted 24/09/13 01:01 AM Hi, I have a stock (not tuned) BA xr6 turbo. Recently I noticed that my boost gauge was hitting around 15PSI.I took the car to the local mechanic / dyno place, he check the car and said “looks like your boost solenoid is faulty”. He said that he got the air compressor and put little amount of air to the actuator & it move fine. He bypassed the solenoid and connect the pipe from the turbo direct to the actuator. Then I was getting 6-7PSI.I bought a new Boost Solenoid and replaced the old one and reconnect the pipe back to normal. I get 14 – 15PSI. So then I did the bypass and connect the vac pipe from the turbo direct to the actuator, I get 10-12PSI….Ive check for air leaks but couldnt see any.Can someone suggest what’s going on with my car and how can I fix it.Thanks Link to comment Share on other sites More sharing options...
PSI O6T Donating Members 440 Member For: 12y 5m 3d Gender: Male Location: sydney Posted 24/09/13 01:10 AM Share Posted 24/09/13 01:10 AM does it have a standard cat/exhaust ? 1 Link to comment Share on other sites More sharing options...
XR-MAKO New Member 18 Member For: 16y 8m 28d Gender: Male Location: Sydney Posted 24/09/13 01:13 AM Author Share Posted 24/09/13 01:13 AM Yes, everything is standard Link to comment Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 4m 19d Gender: Male Posted 24/09/13 01:50 AM Share Posted 24/09/13 01:50 AM Faulty boost gauge? 1 Link to comment Share on other sites More sharing options...
Skids4kids in the mid....not the bum like some Member 609 Member For: 11y 9m 23d Gender: Male Posted 24/09/13 01:51 AM Share Posted 24/09/13 01:51 AM Does the actuator swing arm assembly swing freely when some air is applied to actuator?Is the car hitting boost cut at all as in a rough ignition cut feel...over boost on a stock car is usually caught by around 8psi so this is really unsafe having 15psi come up.What does she go like lol? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 20d Gender: Male Location: @ my laptop Posted 24/09/13 01:58 AM Share Posted 24/09/13 01:58 AM sounds like you have a faulty actuator and your car has a tune in it 1 Link to comment Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 10m 19d Gender: Male Location: Canning Vale, W.A Posted 24/09/13 02:02 AM Share Posted 24/09/13 02:02 AM I'm gonna lock in A. possible fualty boost gauge. Without driving the car it's hard for any of us to truely diagnose the situation.. it may be fine. Link to comment Share on other sites More sharing options...
XR-MAKO New Member 18 Member For: 16y 8m 28d Gender: Male Location: Sydney Posted 24/09/13 02:05 AM Author Share Posted 24/09/13 02:05 AM Does the actuator swing arm assembly swing freely when some air is applied to actuator?Is the car hitting boost cut at all as in a rough ignition cut feel...over boost on a stock car is usually caught by around 8psi so this is really unsafe having 15psi come up.What does she go like lol?I will have to test the actuator swing freely myself, as I can only go by what the mechanic said.She is flying when I hit boost. I driving it without hiting boost as I dont want to break anything.There is no rough feel before or after boost Link to comment Share on other sites More sharing options...
XR-MAKO New Member 18 Member For: 16y 8m 28d Gender: Male Location: Sydney Posted 24/09/13 02:07 AM Author Share Posted 24/09/13 02:07 AM I'm gonna lock in A. possible fualty boost gauge.Without driving the car it's hard for any of us to truely diagnose the situation.. it may be fine.I dont think its the gauge, as its pulling very hard and you can hear the turbo spooling loud. Didnt do that before Link to comment Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 17y 10m 19d Gender: Male Location: Canning Vale, W.A Posted 24/09/13 02:14 AM Share Posted 24/09/13 02:14 AM might be time to upgrade the actuator mate in which case you may as well port the rear housing at the same time as it'll require you taking the turbo off (those labor costs!!) Link to comment Share on other sites More sharing options...
