tfc Member 28 Member For: 13y 5m 22d Posted 22/09/13 07:26 PM Share Posted 22/09/13 07:26 PM Hi All, Running a 2009 FG ute with a few basic mods, pulling 290kw at the wheels. Noticed turbo had been making a noise after switching off engine in last few weeks.Pulled out on the freeway, hit the go pedal and heard a little tinkle of a noise, then had no boost at all, engine running fine.After about 5 seconds, HUGE amounts of white smoke pouring out the exhaust (pretty much blocked the freeway) pulled straight over.Just towed it home. Any ideas what is going on?Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/ Share on other sites More sharing options...
Pazzo Donating Members 11,132 Member For: 14y 5m 23d Gender: Male Posted 22/09/13 07:53 PM Share Posted 22/09/13 07:53 PM New turbo... That one is gooooooooooooone Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427263 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 24d Gender: Male Location: WA Posted 22/09/13 10:04 PM Share Posted 22/09/13 10:04 PM How many km on the car? Sounds like the turbo bearing has given way and therefor flogged the seal. When you change it be sure to check the turbo oil feed filter as it is very common for these to bloke up. Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427270 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 17d Gender: Male Location: Canning Vale, W.A Posted 22/09/13 10:27 PM Share Posted 22/09/13 10:27 PM Yep blocked feed, new turbo for you buddy! Gtx time Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427271 Share on other sites More sharing options...
tfc Member 28 Member For: 13y 5m 22d Posted 23/09/13 12:02 AM Author Share Posted 23/09/13 12:02 AM Thanks blokes! I thought as much.... could be that bloody filter, wish I had pulled it out now. Should have seen the smoke!! Like a bushfire! Funny thing was I had just done a proper overtake on a few cars and then booooom smoke, the cars I had overtaken couldn't go past until it had cleared! Cops appeared from nowhere 'we thought someone was doing a burnout'. That would be the biggest burnout I have ever seen Car has done 80,000 km, been modded for about 15K. I do abuse it a fair bit.Time for a bigger and better turbo, might trawl the forum for ideas.Currently running 4" dump, big injectors, herrod intake making 290rwkwI did love the low down power made by the small FG turbo.Anyway, any ideas let me know!Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427287 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 24d Gender: Male Location: WA Posted 23/09/13 01:12 AM Share Posted 23/09/13 01:12 AM Gtx3582r is 1500 from CMS. Plus a tune and warlbro 450 in tank pump for about 220 bucks Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427303 Share on other sites More sharing options...
AzMahoony Hench, but no longer shredded or tanned. Member 3,343 Member For: 18y 17d Gender: Male Location: Canning Vale, W.A Posted 23/09/13 01:16 AM Share Posted 23/09/13 01:16 AM Get either the gtx 3576 or 3582 depends on how far you wanna go.. (350-370) or 380-420+) on pump 98.. with an upgraded fuel/surge tank setup. MOST tuners will fit it up for free if you get them to port the wastegate and upgrade the actuator. Costs vary depending on the workshop. The GTX is on special indefinitely @ CMS for around 1600 delivered to your door. He charges an extra 15$ to tap the actuator bleeder nipple into the face. Best of luck mate! Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427304 Share on other sites More sharing options...
tfc Member 28 Member For: 13y 5m 22d Posted 23/09/13 02:08 AM Author Share Posted 23/09/13 02:08 AM Sounds like a plan... How do the 3576 and the 3582 go for lag? Assuming you mean CMS Sydney? Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427312 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 11y 11m 24d Gender: Male Location: WA Posted 23/09/13 02:31 AM Share Posted 23/09/13 02:31 AM I love the 82r and will net you about 410wkw with the right sustaining mods. But I have an auto. Others like the 76r and will net you around 360wkw with the right sustains mods. The 82r is on full boost by 2600rpm. The 76r I cannot comment on. Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427317 Share on other sites More sharing options...
Vevapower Waiting for the 1st N/A 12! Donating Members 2,533 Member For: 17y 2m 3d Gender: Male Location: Sydney Posted 23/09/13 03:14 AM Share Posted 23/09/13 03:14 AM GTX82 for men GTX76 for women. 4 Link to comment https://www.fordxr6turbo.com/forum/topic/86338-fg-xr6t-ute-no-boost-lots-of-white-smoke/#findComment-1427331 Share on other sites More sharing options...
