fpv229 Member 15 Member For: 12y 10d Gender: Male Posted 24/09/13 01:15 AM Author Share Posted 24/09/13 01:15 AM cheers, so you guys would recommend cams. what brand have you gone for as im looking around and also whats the price range where looking at? Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427529 Share on other sites More sharing options...
CHLAXN Donating Members 932 Member For: 16y 11m 15d Gender: Male Location: north QLD Posted 24/09/13 01:33 AM Share Posted 24/09/13 01:33 AM Why waste you money on cams mate with the stock turbo? Your not going a built bottom end so gains would be very minimal. There is no need to change them stock bf ones will be fine. Better off using the money on getting your oil pump gears done. 2 Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427533 Share on other sites More sharing options...
MA91CK billet turbos and weathered engines dont mix Donating Members 1,346 Member For: 12y 11m 15d Gender: Male Location: Wollongong Posted 24/09/13 01:35 AM Share Posted 24/09/13 01:35 AM (edited) On 22/09/2013 at 12:54 AM, BRK said: Well, it is not top end but pistons and rods if you want to go all out power wise - plenty of choices and IMO the dollars are reasonable for what you get.The heads on these things work well so other than a basic clean up / inspect / service a big dollar port job is not essential - have a look at the 400RWKW posts for guidance. However, there are success stories with headwork. Very much a personal choice and requires research - you do need to find someone who knows this sort of work.Quality valve springs for sure. Camshaft changes - well, there are reports of good results and not so good results. If it is a BA, it does seem that the factory FG cams are a mild improvement and provide no issue for tuners. After that, it depends on the type of performance you want and how much you want to pay. It is also something you need to discuss with the tuner. On 22/09/2013 at 3:52 AM, fpv229 said: well I am ordering a new bottom end on monday so there goes the idea of forged pistons, etc.just more wanting to know what sort of upgrade are worth in the top end and if its even worth touching it?I.e port and polishing the heads, valves, valve springs, cams?? if anyone has any info would be greatYou got your answer there. I can see you just want to hear yeh change cams itll be good. Mate if you want to change cams, change them. Not necessary, theres guys running HUGE power with stock ones. But if you after that nasty worked sound, then by all means go ahead. All depends on how much money you have to play with mate. Id first be looking at valve springs and oil pump gears, THEN worry about cams. They do sound mean with a decent set.Just my $0.02 Edited 24/09/13 01:36 AM by MA91CK 4 Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427534 Share on other sites More sharing options...
HSV ETR Member 131 Member For: 12y 9m 15d Gender: Male Location: Brisbane Posted 24/09/13 08:27 AM Share Posted 24/09/13 08:27 AM I only did cams soley because of the sound and the fact I was doing my springs and its a matter of just swapping the cams over lol but u cant really complain about a 40rwkw gain on the same boost for the price of $1150 Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427614 Share on other sites More sharing options...
fpv229 Member 15 Member For: 12y 10d Gender: Male Posted 24/09/13 10:49 AM Author Share Posted 24/09/13 10:49 AM what cams did u use mate? Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427654 Share on other sites More sharing options...
RIP85 REST IN PEACE V8 Donating Members 469 Member For: 17y 16d Gender: Male Location: Woodridge on the park bench Posted 24/09/13 10:52 AM Share Posted 24/09/13 10:52 AM Have to agree about cams I'm running atomic 4.5 plus with the vct on 16psi on bp 98 car made 400rwkw my tuner said same mods no cams cars are around the 350rwkw mark Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427656 Share on other sites More sharing options...
fpv229 Member 15 Member For: 12y 10d Gender: Male Posted 24/09/13 11:12 AM Author Share Posted 24/09/13 11:12 AM whats the oil pump do and what aftermarket ones would u go..also what price range are they as im abit strapped for cash atm.and yeah the cams honestly are for the sound mostly lol 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427667 Share on other sites More sharing options...
robbay91 Member 68 Member For: 12y 9m 18d Gender: Male Posted 24/09/13 12:13 PM Share Posted 24/09/13 12:13 PM is $1150 for the set or each? Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427674 Share on other sites More sharing options...
HSV ETR Member 131 Member For: 12y 9m 15d Gender: Male Location: Brisbane Posted 25/09/13 03:01 AM Share Posted 25/09/13 03:01 AM 1150 for the set and yes I also use the atomic stage 4+ without fixed gears and and hi stall auto.. it all comes down to who tunes it and yess me and rip85 get our cars tuned at the same place in brisbane Link to comment https://www.fordxr6turbo.com/forum/topic/86326-rebuilding-top-end-of-motor-whats-good-to-change-for-power/page/2/#findComment-1427761 Share on other sites More sharing options...
