Gtx3576R.
xrr40l
  • Member For: 19y 6m 25d
I have a single 50mm off the merge collector (average angle too) and don't have any issues controlling boost.
Good to see Garrett finally have a new turbine on a GT35 frame. Still no EFR though!!
  • Moar Powar Babeh
  • Member For: 19y 4m 9d
I'm facing a similar dilemma at the moment in making a single gate function on a spilt pulse manifold.-
Runners are completely divorced at the collector
My plan is to add a separator plate between the runners (and extend into the elbow) and use a 50mm stand off (will be using my 45mm hypergate)
Angle will be similar this with the end angle cut to A: position the gate correctly B: Have max area available for the gas flow
  • Member For: 11y 4m 2d
I'll add some picks of mine when I fly home in the next couple of days Ralph. I used 2x 40mm bends off each side of the collector then made a 40mm 2into1 merge into the gate. Basically how your holding it is how 6boost do it but they put it at 90* to the merge which is obviously terrible for flow. Facing it like you have is a lot better to promote the gas flow into it but still may lead to trouble if each divided half isn't big enough.
  • Moar Powar Babeh
I know what you mean mate, 6boost used to do them like that back in the day. I may go that way but also looking for simplest solution fab wise!
I planned to angle mine is it's basically inline with the entry angle from the inner two primaries on each side (does that makes sense??)
You'll also be happy to know this has happened-
and it's not going back on.
  • Carnage on the Garage Floor
  • Member For: 14y 8m 21d
I'm running a v band housing and single entry so the merge is pretty straightforward.
  • Like 2
  • Bronze Donating Members
  • Member For: 8y 5m 18d
^ nice and light too. Has anyone tested the tial v split pulse back to back to see results?
Proper split pulse though so either twin gate or split  gate off the collector, and not just a single pipe?
Not mine obviously but is this a possibility for you Mr Wiggam?
14702274_1354533171237610_81390554997948
Edited by Bomber
