  • Member For: 11y 3m 29d
Short answer yes
Which ones - pretty sure all of precisions ball bearing range
The experts will chime in shortly
  • Carnage on the Garage Floor
  • Member For: 15y 30d
New modified 35/40 for $550 or just bolt wheel to old chra with new bits?
I think if you know the chra is low klm and healthy plus together with vsr balancing with the new wheel it's still viable then ok. If getting down to like a few hundred though you'd be better to go brand new out of box imo.
True that
When the gtx3576 had came on special was very tempted
Only thing that stopped me was halfway thru doing the same as mattyp - had bought a 3540 with 12lb actuator ($300!!) from a member on another forum
Already bought a Kinugawa 7 blade billet wheel and got port job and vsr done at mtq
Otherwise would have been a no brainer
  • MattyP
  • Cruise Control
  • Member For: 13y 1m 6d
So I've got a project coming up with a Spare FG turbo ive got lying around.
For my birthday I'm going to be buying a GT3076 11 blade billet wheel and gt3076 .6 cover
http://www.ebay.com.au/itm/Garrett-Compressor-housing-GT3076R-76mm-56-trim-wheel-anti-surged-t04e-4-inlet-/380115888079
http://shopping.kinugawaturbo.com/turbobilletcompressorwheelgarrettgt3037gt3076rgt30r57762mm56trim11blades.aspx
I'm almost certain it'll bolt up to the 35r CHRA.
I'll keep everyone posted with it.
Ive noticed that the specs are almost identical to a GTX3576...
This maybe a relatively inexpensive way of geting a high powered well spooling turbo for around $500
Let's see how we go.
  • Like 4
  • MattyP
  • Cruise Control
Thanks man
The billet wheeled 3540 is going well, I just would like to see how it goes and get a bit more response for hopefully the same amount of power or it to be comparable
