Ba Xr6T 4 Speed Limp Mode -
Peter_M
  • Member For: 13y 10m 21d
I also remember hearing a click noise when I started the car afew times a while back, could this be related?
Also just did the test, car dropped to about 10 when car was started...
Edited by Peter_M
Maybe try unplugging wiring looms etc and plugging back in, maybe connector to ecu is a bit loose.... But yeh don't have an auto so can give much more advice really. The lean code and wastegate code etc would be related to car being in limp mode I'd assume. Are u sure u weren't giving car a flogging?! ;) what's car doing now after codes have been cleared??
Thanks for your help so far its been great. Battery got tested today and its fine. Everyone is pushing me towards the ECU being fried... Is there anyway I can test the ECU? Autologic has quoted me $120 for the test (I need to remove and physically give them the ECU), then if it needs repairing, they waive the test fee and just charge the repair fee.
I'm not really sure of what else to do, all the plugs seem to be in fine, connector on auto is fine, earth is fine... theres nothing in the coolant...
I HATE THIS!
  • Member For: 16y 30d
There's water in your box mate I'm inclined to think stock g/box cooler or aftermarket anyway if you want get the BA workshop manual on Google go thru the pin point tests will have all the correct volts you should be reading for normal operation on the 4spd looms and solenoids have you gone past dions if you haven't you should
And 100% DTM is in Geelong
Edited by KeddyXR6T
