connorebrown Member 11 Member For: 11y 8m 14d Posted 17/09/13 05:45 AM Share Posted 17/09/13 05:45 AM Hey guysJust a few questions you propabley know the answers to....1. What are the best tyres to use with a xr6 turbo manual with aprox 430hp 18psi safe tune?2. Are the Bf mkii gearboxes and clutches strong enough to handle that much power withou fault?3. And whats the best intercooler kits to look at for this model and year? Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/ Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 24d Gender: Male Location: SW Sydney Posted 17/09/13 06:03 AM Share Posted 17/09/13 06:03 AM We can answer these questions easily, however for you to find a solution you will have to search the hundreds of topics covering all of these points. 1. The best tyres are the best ones you can afford, don't skimp on tyres if you want traction. Nitto Invo's are fairly popular and well priced2. The gearbox will hold plenty of power, the clutch won't last long at all. Mal Wood has a great range of products for your car3. Process West, Nizpro and Plazmaman have great kits for the falcons, any of them will be great. Do some more research with what mods people have done and the power they have gotten, your figure of 430hp running 18psi with a stock intercooler seems optimistic. If it does in fact make that sort of horsepower then I would say it is only for the first run on a dyno before heatsoak kills the performance. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425852 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 11d Gender: Male Location: Vic Posted 17/09/13 06:04 AM Share Posted 17/09/13 06:04 AM (edited) Stock clutch fine just don't try not to load it up too much in 5th &6th. Plenty of tyres will hold that, what size wheels do you run?As for coolers, Plaz, process west, and nizpro will all help.Edit. Beaten by senna. 430ho should be on around 12.5-13psi max. Edited 17/09/13 06:05 AM by Henz 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425853 Share on other sites More sharing options...
connorebrown Member 11 Member For: 11y 8m 14d Posted 17/09/13 06:18 AM Author Share Posted 17/09/13 06:18 AM (edited) I havnt braught the car yet but the guy im looking to buy it off has had a dyno and he has the sheets to prove as well, hes had plenty of mods.only stock 17ich aloys atm when he took me for a test drive they didnt seem to hold very much traction at all.....what do you mean about loading up 5th and 6th?and is loading 18psi to much for the car? Edited 17/09/13 06:25 AM by connorebrown Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425855 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 11d Gender: Male Location: Vic Posted 17/09/13 06:26 AM Share Posted 17/09/13 06:26 AM Who tuned it? Those numbers are no good man, I would steer clear! That boost to power, somethings definitely wrong, maybe unhealthy motor pushed hard to make a figure.Leaving it in 5th-6th and holding it at WOT will load the clutch right up, and that's were you'll see signs of slip first. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425857 Share on other sites More sharing options...
connorebrown Member 11 Member For: 11y 8m 14d Posted 17/09/13 06:51 AM Author Share Posted 17/09/13 06:51 AM He had everything done at house of power plenty of mods which include:- o ring compressor- exaust outlet gasket- oil drain gasket- lockplate turbine end- gasket small base- strip and clean turbo- machine turbo housing- coolant tank supply- turbo studs- nut turbocharger- turbo oil supply line- ngk spark plugs- 4inch turbo dump pipe- hi flo 3 1/2 race cat- bolt and gasket kit- siesmens 60lb injectors 14mm high imp- walbro gss341 fuel pump 550hp- intake fuel filter- custom tunethat's the mod list he sent me.and all the dyno sheets defiantley say 433hp max at just under 18psicar still has very low ks aprox 75 000, he want around 18k for it.....very hesitant now please help......... Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425864 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 3m 24d Gender: Male Location: SW Sydney Posted 17/09/13 06:59 AM Share Posted 17/09/13 06:59 AM Most of that list is repair parts, although there are some good power parts. Needs an intercooler asap though, that's why he has to pump 18psi to make that much power Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425867 Share on other sites More sharing options...
connorebrown Member 11 Member For: 11y 8m 14d Posted 17/09/13 07:10 AM Author Share Posted 17/09/13 07:10 AM with a new intercooler kit and tune would she be an alright car?should I go for the buy? Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425869 Share on other sites More sharing options...
Henz Tampon inserted, Auto Acquired, next purchase a new handbag Donating Members 9,946 Member For: 17y 2m 11d Gender: Male Location: Vic Posted 17/09/13 07:10 AM Share Posted 17/09/13 07:10 AM There's like $1000-$1300 in performance parts there. For a manual bf2 your going to pay that sorta $$ but yeaaaa, who tuned it? Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425870 Share on other sites More sharing options...
connorebrown Member 11 Member For: 11y 8m 14d Posted 17/09/13 07:16 AM Author Share Posted 17/09/13 07:16 AM HOUSE OF POWERgood place or not? Link to comment https://www.fordxr6turbo.com/forum/topic/86279-2006-bf-xr6-turbo-manual-mkii/#findComment-1425873 Share on other sites More sharing options...
