fgxr6t89 Member 16 Member For: 12y 9m 18d Gender: Male Location: Melbourne, South East. Posted 16/09/13 03:21 PM Share Posted 16/09/13 03:21 PM Hi, just wondering if anyone knows what oil pressure the ford fg xr6 turbo's should be getting. I have a oil pressure gauge connected to an oil filter sandwich plate and I'm getting around 50 psi. Does anyone know if it should be higher or lower? Im also usin 0w40 castrol edge oil but im thinking of going a 15w40 as recommended by ford. Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/86278-fg-xr6-turbo-oil-pressure/ Share on other sites More sharing options...
Lennox Member 2,586 Member For: 12y 3m 25d Gender: Male Location: Perth Posted 16/09/13 09:52 PM Share Posted 16/09/13 09:52 PM Well I'm no expert but mine was the same with edge 0w40 22ish psi idling hot, around 50 while accelerating hot. When it's cold it's like 50 idling 70 odd accelerating Link to comment https://www.fordxr6turbo.com/forum/topic/86278-fg-xr6-turbo-oil-pressure/#findComment-1425681 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 2d Gender: Male Location: Christchurch, New Zealand Posted 17/09/13 04:31 AM Share Posted 17/09/13 04:31 AM In a BF the mins are 19 at idle and 43 at 2000rpm. I doubt its changed with the FG. Keep the 0w40 as your still a 40 weight even if you change it, the 0 just means the viscosity is closer to the 40 visc at startup. Link to comment https://www.fordxr6turbo.com/forum/topic/86278-fg-xr6-turbo-oil-pressure/#findComment-1425819 Share on other sites More sharing options...
TomT Spooling Member Donating Members 961 Member For: 13y 6m 14d Gender: Male Location: Blue Mountains, NSW Posted 17/09/13 10:46 PM Share Posted 17/09/13 10:46 PM Since my gtx upgrade I'm seeing when hot my oil pressure can get down to around 16psi on idle, whereas it used to be around 19-20 Pressure still fine when driving. Could this just be because slightly lower idle rpm with new injectors? Or what? Link to comment https://www.fordxr6turbo.com/forum/topic/86278-fg-xr6-turbo-oil-pressure/#findComment-1426062 Share on other sites More sharing options...
