griever Inactive Members 1 Member For: 11y 3m 24d Posted 12/09/13 09:22 AM Share Posted 12/09/13 09:22 AM I have a BA that is putting up error code of too much boost. When you floor it when it gets to about 100kph, it loses power and then regains it. I put it on a dyno and the boost didn't go over 7lb. I am wondering if it is a sensor problem because the motor is sensing there is too much boost and then it shuts itself down to protect the motor. Can anyone help identify the problem, is it a sensor, the computer, or the actuator thing which opens the wastegate? Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 7m 9d Gender: Male Location: @ my laptop Posted 12/09/13 10:38 AM Share Posted 12/09/13 10:38 AM all the above can be a problem and your car should not even be getting 7 psi Link to comment Share on other sites More sharing options...
maiseyF6 Member 19 Member For: 12y 2m 13d Posted 12/09/13 11:53 AM Share Posted 12/09/13 11:53 AM if u have the equipment, hook up a regulator to your wastegate line and take note at how many pound of pressure it STARTS to move and how many pound its at once fully actuated. This will rule out the wastegate actuator if it tests ok at around 6-7 psi, my guess is MAP sensor (manifold air pressure), which is what reads boost pressure, is reading too much than what it should be, wouldn't hurt to check and make sure its not caked with crap or the electrical plug full of dirt or something, just start testing stuff mate Link to comment Share on other sites More sharing options...
