  • Member For: 19y 1m
there is also no mention of the rear cradle which has torn mounts or a new roof lining, can the roof lining be replaced without removing glass?
  • Member For: 18y 8m 30d
My cousin hit a gutter in his vn, I know it have a different diff setup but because of the impact to the wheel, it punched the diff over 3", punched out the rhs guard, snapped the diff mounts and cracked 2 rims. Also the rhs door wouldn't shut properly
  • blind leading the blind
  • Member For: 16y 9m 17d
I'm no expert at all but I would have thought that the broken parts in the suspension has probably absorbed some of the impact. Maybe the vehicle won't be too bent. I have seen a lot worse repaired. If he finds a. Good panel beater who is willing to work with him it shouldn't be too bad.
  • Member For: 14y 9m 23d
DO NOT TRUST FORD PRO!!!!!!
These are the ones that attempted to fraud me with an LPG motor with a red rocker cover and called it an FG 09 turbo motor with 12000kms..... Tuner down your way has experienced this as well.
Run away!!!
  • Like 3
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 3m
I tried to like the sh*t outta that, but I could only manage the 1 :turboboink:
  • Like 4
  • Member For: 12y 7m 22d
Thanks for the heads up rod. No way I'm leaving my car with them to fix, wouldn't be surprised if they pull some good parts out of my vehicle and fit faulty ones. they don't seem too professional, do they?
Nah mate they really aren't, were hard to deal with, wouldn't freight engine and kept blaming couriers, and when it finally turned up it was a dodgy engine!!! They then tried to tell me that this was the engine in the car..... I said "well walk out and have another fkn look!!! Surely u wouldn't miss the fact it's a standard fkn falcon!!!" Plus they purchasd the red rocker cover from a tuner down there to put on my engine and were sooo stupid and left that tuning companies sticker on it!!. Rant over.....
But yeh don't know if rear cradles etc have serial numbers etc but I'd definitely check them and DO NOT leave your car with them.
Good luck mate hope u get it fixed up.
  • Moderating Team
  • Member For: 22y 4m 27d
How hard did you hit the kerb?
Im a panel beater by trade, and wondering if the suspension took all the impact.... can you see any creases in the floor under the carpet, or near the sills? still got me scratching my chin on how the side airbags deployed.
