  • Moderating Team
  • Member For: 22y 4m 28d
Just going off the old AU days, you would need to remove the vertical window runner somehow...
It may be pop riveted in the top of the door, and bolted further down in the guts of the door.
Once the window runner is removed, the glass should push forward.
But this is for AU, so BA BF FG ive never done one....
  • Moderating Team
You would have to drill them out.
If you want to wait, I can cruise over on Monday and give you a hand? I've got Nightshift tonight, then I'm off to a wedding for the weekend.
  • Member For: 12y 7m 22d
no paint needed, got same colour panels off a g6et, very lucky. Painting would have been expensive. Saved some money by installing SRS module, airbag, roof liner, door and sideskirt myself
Tow from accident to home $320 ish
Airbag, module, roof liner $380
tow from home to mechanic $90
New rear cradle (fitted) $1000
Door $250
sideskirts $150
MS700 inspection and tips free :D (appreciated)
Total $ 2190
Edited by sct911
  • Like 2
  • Member For: 14y 8m 9d
What about the wheels and tyres? Pretty cheap considering the damage. Have you had the chassis checked to make sure its 100% straight? Didn't hit that hard but still worth checking
nothing needed to be done regarding wheels and tyres, just used spare rim . Not going to bother with chassis check, if it is bent, so be it, I'm still keeping the car. Had the car checked out by knowledgeable people while car was on stands at home, should be fine.
