  • FREAKY
  • Member For: 15y 6m 2d
dunno , just going by the same accident I saw.
didnt think fords had that fancy technology
soooooooo your saying that if my car stops suddenly going straight (eg a chain to my tow bar) that the front air bags will go off?
Edited by Ford Freak
  • Member For: 18y 9m
  On 11/09/2013 at 6:06 AM, Ford Freak said:
are you sure?
seen a xr near my place do the exact same damage, no air bags. as he only hit gutter.
since when do air bag sensors get fitted to the wheels?
It's an inertia sensor...not a physical switch that detects contact. Doesn't matter what hits where, if the vehicle is moving in a given direction and stops suddenly then airbags on the forward edge (in this case the side of the vehicle) will deploy.
They are essentially designed to cushion the body from hitting the interior of the car - not to prevent the object (gutter/tree/oncoming vehicle) from hitting the occupant.
The sudden stop would have been registered by the SRS computer which deployed the air bags.
  • Sucker
  • Moderating Team
  • Member For: 21y 2m 3d
:spit:
Yes Freaky, exactly. Doesn't matter what/how the vehicle is stopped.
The actual main module sits in front of your gear selector. There are also additional sensors behind the front bumper, but the one that does most of the work is right in the centre of the cabin.
  • Member For: 19y 1m
are you sure?
there is no sensor in the door, as the others have said, there are different sensors around the car if a certain deceleration G force is met, then the bags will deploy , no matter what part of the car has hit what
  • FREAKY
quoted from net
Like the frontal airbags; side impact airbags must have a crash sensor to recognize that a crash has accured. These sensors are usually mounted in the front door, the B post, or most are located inside of the rocker panel just below the B post.
  On 11/09/2013 at 6:27 AM, Ford Freak said:
quoted from net
are you trying o take over from wikipellor?
  • Like 3
  On 11/09/2013 at 6:37 AM, tab said:
:surrenderwave:
Should we move on to seatbelt pre-tensioners now?
which is why I mentioned earlier there may other things that need to replaced
