TTJET New Member 7 Member For: 20y 2m 6d Posted 08/06/05 09:59 AM Share Posted 08/06/05 09:59 AM I think you will find he is from the dark side and has a vl turbo Link to comment https://www.fordxr6turbo.com/forum/topic/8617-how-much-power-do-you-want/page/21/#findComment-261085 Share on other sites More sharing options...
Martman Member 6 Member For: 20y 2d Posted 03/07/05 01:50 PM Share Posted 03/07/05 01:50 PM We are building an XR6 Turbo engine for our new project car.Previously we have only been using the toyota 2JZGTE supra engine's so I am unsure of what to expect from this engine.So far we have High Flow injectors, a/market pistons, conrods, and valve springs.We are getting the valves multi-angled and a small amount of cleaning in the ports.We will run the system with a Motec M600 ECU.We will probably run around 15 to 18 pounds off boost depending on how things go.What sort of power output do you think we will get with this sort of setup?Previously we were just under 500hp with the standard 2JZ engine with a/market turbo's running 20psi boost. We are hoping that we will get more but really not too sure.??Matt Link to comment https://www.fordxr6turbo.com/forum/topic/8617-how-much-power-do-you-want/page/21/#findComment-269281 Share on other sites More sharing options...
CnC SportCompact.biz Member 328 Member For: 22y 1m 9d Location: Canberra Posted 12/01/06 04:55 AM Share Posted 12/01/06 04:55 AM Martman, I think you could be looking at around 400kw @ the wheels quite comfortably. What transmission are you going to channel this through? Link to comment https://www.fordxr6turbo.com/forum/topic/8617-how-much-power-do-you-want/page/21/#findComment-333960 Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 3m 28d Posted 12/01/06 05:44 AM Share Posted 12/01/06 05:44 AM We will run the system with a Motec M600 ECU.<{POST_SNAPBACK}>You will get a much better result if you use the factory management. Throttle control, cam control, injector control etc. all superior with the Ford hardware Link to comment https://www.fordxr6turbo.com/forum/topic/8617-how-much-power-do-you-want/page/21/#findComment-333971 Share on other sites More sharing options...
Martman Member 6 Member For: 20y 2d Posted 13/01/06 09:43 AM Share Posted 13/01/06 09:43 AM We are using the motec as it is going into a purpose built race car that is not a falcon, so we have no falcon loom sensors etc etc.This is actually an old post now.We have had it running and it is running a hollenger sequential gearbox.We have had a series of engine failures due to different things,and so we have not have as much boost into it as we had hoped.Our best so far was 360 kw at the rear wheels on a rolling road dyno with about 13psi boost. Martman Link to comment https://www.fordxr6turbo.com/forum/topic/8617-how-much-power-do-you-want/page/21/#findComment-334610 Share on other sites More sharing options...
