  • Premium Donating Member
  • Member For: 21y 7m 22d
  • Location: If it says ONLINE below, in front of the computer, if not, tearin' up some bitumen!
I know I've already answered this thread but my goals have changed a little.
So to answer "how much power do I want?"............
Enough to wipe the floor with any LS1 at their Nationals! :thumbsup:
  • Replies 204
  • Member For: 22y 3m 4d
  geea said:
Hi Peter, you state that after the cat there is 2psi of back preasure at 240kw. I have a couple of questions.
What is the back preasure of the standard system with the standard cat and would you know (or have an educated guess) at what the back preasure would be of the standard system with the centre muffler removed? In the original system is the cat the biggest restriction or would either the centre or rear mufflers be more restrictive?
With the APS scratch and dent exhaust is the $2000 including fitting and if so are there any left?
Thanks Geea.
Hi geea
From memory the total exhaust system back pressure at stock power (240Kw) is approx 7 Lbs, and with the centre muffler removed total B/P ia approx 6 to 6.5 Lbs.
Most of the B/P is in the engine pipe and stock cat converter (approx 4 to 5 Lbs) this is why APS designed a 3.5'' high flow cat converter as all of the 3'' cat converters we tested are no better than the stock FORD cat converter.
The price does not include installation which is approx a 2 hour job, as removing the stock exhaust is time consuming in particular removing the tail pipe rear muffler assembly is difficult.
We have one full exhaust system left in stock (most were sold on friday) so let me know ASAP if you want it. Hope this answer all of your questions.
PETER
APS
  rapt said:
Thanks Peter
All going well with tax return will be contacting you soon  ;)
rapt no problem,
Dont let the wife/girlfriend know your tax return is coming other wise you will miss out. :blush:
Peter
aps
  • 2 months later...
  • Member For: 21y 3m 23d
Peter,
My xr6 ute is 4k's old. Im loooking for a little bit more performance for passing etc. Its not used fro track days or quarter sprints. What would an upgrade cost keeping the vehicle as close to stock as I can without compromising mechanical reliability.
Regards
  • Member For: 21y 2m 28d
  cougarcatman said:
Peter,
Regards
good question cougarcatman, I was just about to ask the same only difference mines done 7500kays any help would be great thanks
  • Member For: 21y 3m 28d
I would recommend the "old" stage one from APS. Its Piggyback ECU only and will up the power from the stock 240fwkw to about 280 fwkw. It will also make the car more drivable and give you better fuel economy :blush: The cost is about $1650 fitted and tuned, it is also completley removable if anything should happen that required a warranty on the drive train :nono:
The New Stage one now includes 6 fuel injectors and will take the car to 300fwkw
I will be doing this mode before the year is out.....that is if I get my car this year......My car must be on the slow production line :thumbsup:
  • Member For: 21y 4m 9d
Talking about utes.. I noticed in the latest performance fords mag.. one of the advertisers had the APS phase 2 kit on special from $5900 to $5600 if I remember correctly... it then stated that this price is for sedans only... does this mean utes are more expensive??
If this is the case... would it mean that all phases are more expensive for the ute??
  • Here since the start...
  • Member For: 22y 1m 16d
I would guess the reason would be because they probably have sedan kits in stock and want to move them. The ute kit would be different because of the different exhaust.
