Nolathane Diff Bush Noise Resonating Through Rear End.
mick1378
  • Member For: 17y 6m 8d
My diff was quiet before install. Ford Darwin did it for me. I'm not sure how many aftermarket ones they have fitted. Do you fit the superpro differently to standard?
Is there anything I should look for to spot if they have done anything wrong?
  • Silver Donating Members
  • Member For: 12y 10m 17d
Someone else will be able to clarify better than me, but I'm fairly certain there's an art to installing the super pro bushes correctly. It's not uncommon for it to be done wrong, which will induce extra noise. Many people, especially with autos, reckon there's minimal extra NVH with comfort spec super pros.
How often do you change your diff oil? When did you change it last?
  • Moar Powar Babeh
  • Member For: 19y 4m 7d
If the side bushes aren't installed to correct depth (which varies and must be measured when the factory units are removed) the outriggers can either contact the diff cradle and transmit noise or contact the cradle momentarily on shifts.
You should not experience any nvh increase with properly installed COMFORT series bushes.
  • Like 2
  • Bronze Donating Members
  • Member For: 12y 6d
Sydney suspension installed mine (formerly wholesale suspension) . I just get the wine , no clunking noises.
Might have to join stripes and buy a Expensive Daewoo lol
Edited by LU82
  • Moar Powar Babeh
I run superpro race spec sides with a comfort centre. No extra nvh. I installed the front bushes to the exact distance the previous ones.
You have solid race specs side bushes and no noise? Do did already have high level hearing loss?
  • Member For: 13y 6m 10d
Correct. And serious it's quite as.
It's only the solid centre that transmits the noise. My original setup was genuine Ford sides with a solid centre and it hummed real bad. Swapped out the centre back to a genuine Ford and it was quite again
After they died I went to the current setup of solid sides and comfort centre.
