norrs Donating Members 448 Member For: 17y 6m 8d Gender: Male Location: Darwin Posted 09/01/15 11:12 PM Share Posted 09/01/15 11:12 PM My diff was quiet before install. Ford Darwin did it for me. I'm not sure how many aftermarket ones they have fitted. Do you fit the superpro differently to standard? Is there anything I should look for to spot if they have done anything wrong? Link to comment Share on other sites More sharing options...
LU82 Bronze Donating Members 569 Member For: 12y 6d Posted 09/01/15 11:18 PM Share Posted 09/01/15 11:18 PM Yeah my diff made zero noise with the standard bushes Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 10m 17d Gender: Male Location: Perth Posted 09/01/15 11:20 PM Share Posted 09/01/15 11:20 PM Someone else will be able to clarify better than me, but I'm fairly certain there's an art to installing the super pro bushes correctly. It's not uncommon for it to be done wrong, which will induce extra noise. Many people, especially with autos, reckon there's minimal extra NVH with comfort spec super pros.How often do you change your diff oil? When did you change it last? 1 Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 8d Gender: Male Location: Perth Posted 09/01/15 11:24 PM Share Posted 09/01/15 11:24 PM If the side bushes aren't installed to correct depth (which varies and must be measured when the factory units are removed) the outriggers can either contact the diff cradle and transmit noise or contact the cradle momentarily on shifts. You should not experience any nvh increase with properly installed COMFORT series bushes. 2 Link to comment Share on other sites More sharing options...
LU82 Bronze Donating Members 569 Member For: 12y 6d Posted 09/01/15 11:42 PM Share Posted 09/01/15 11:42 PM (edited) Sydney suspension installed mine (formerly wholesale suspension) . I just get the wine , no clunking noises.Might have to join stripes and buy a Expensive Daewoo lol Edited 09/01/15 11:47 PM by LU82 1 Link to comment Share on other sites More sharing options...
.Stripes. All stock bar the k&n panel filter Silver Donating Members 8,061 Member For: 12y 10m 17d Gender: Male Location: Perth Posted 09/01/15 11:48 PM Share Posted 09/01/15 11:48 PM ^ easy fix lol 1 Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 10d Posted 09/01/15 11:51 PM Share Posted 09/01/15 11:51 PM I run superpro race spec sides with a comfort centre. No extra nvh. I installed the front bushes to the exact distance the previous ones. Link to comment Share on other sites More sharing options...
LU82 Bronze Donating Members 569 Member For: 12y 6d Posted 10/01/15 12:00 AM Share Posted 10/01/15 12:00 AM I Think I must have one of those limited edition ford diffs with extra noise Link to comment Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,323 Member For: 19y 4m 8d Gender: Male Location: Perth Posted 10/01/15 12:12 AM Share Posted 10/01/15 12:12 AM I run superpro race spec sides with a comfort centre. No extra nvh. I installed the front bushes to the exact distance the previous ones.You have solid race specs side bushes and no noise? Do did already have high level hearing loss? Link to comment Share on other sites More sharing options...
gaz097 Bronze Donating Members 1,752 Member For: 13y 6m 10d Posted 10/01/15 01:32 AM Share Posted 10/01/15 01:32 AM You have solid race specs side bushes and no noise? Do did already have high level hearing loss?Correct. And serious it's quite as.It's only the solid centre that transmits the noise. My original setup was genuine Ford sides with a solid centre and it hummed real bad. Swapped out the centre back to a genuine Ford and it was quite again After they died I went to the current setup of solid sides and comfort centre. Link to comment Share on other sites More sharing options...
