ratter Member 6,793 Member For: 19y 1d Gender: Male Location: @ my laptop Posted 03/09/13 07:05 AM Share Posted 03/09/13 07:05 AM the code for generic obd2 codes is the same for all manufacturers, but manufacturer specific codes may have different meanings for the same code number.The Aussie Ford ECU does not know fuel pressure to give a pressure reading Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/page/5/#findComment-1420977 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 12y 1m 7d Gender: Male Location: WA Posted 03/09/13 10:16 AM Share Posted 03/09/13 10:16 AM Yep, sometimes it asks you what make the car is for particular codes such as a dmax fuel leak fault. I will check if it reads fuel pressure on the Fg when I get home. Never the less it does read fuel pressure when it is supported by the vehicle ECM. I'm not here to sell products but I can get them cheap if people want them. Back to the subject at hand. I think that the CReader will give you the info needed to narrow the low power fault down. Or you could buy an Xcal for $700 off a tuner and read your sensor outputs with that. Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/page/5/#findComment-1421022 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 12y 1m 7d Gender: Male Location: WA Posted 03/09/13 11:40 AM Share Posted 03/09/13 11:40 AM Yep as ratter said it doesn't read fuel pressure but it does show your short and long term fuel trims. How did you go with those checks in my earlier post? Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/page/5/#findComment-1421039 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 1d Gender: Male Location: @ my laptop Posted 03/09/13 11:46 AM Share Posted 03/09/13 11:46 AM fuel trims are a good tool to help asses the running of the car, that is assuming the o2 is working correctly and not getting old Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/page/5/#findComment-1421044 Share on other sites More sharing options...
