rapid6turbo Member 56 Member For: 12y 1m 1d Gender: Male Posted 01/09/13 10:42 AM Share Posted 01/09/13 10:42 AM Hi All,Having some issues with my 2005 BA Mkii xr6 turbo.Mod on the vehicle before I bought it:crow HD valve springsngk plugs gapped to .75upgraded intercoolerwalbro intank pump2nd cai modk&n panel filter3" advanaded divorced dump pipe3" advanced cat (not sure on cpsi)36psi (Expensive Daewoo v6) injectors @ 4 bar is about 38psiHP tuners tune for 12psiSo took it to local dyno shop, I live 250km from where it was tuned originally (made 270rwkw 2 years ago)Now making 205rwkw on 12-13psi??? what theThey had trouble connecting to the ECU and got stuffed around there for a few weeks. Then was going to the airport and passed the original tuner on the way, he diagnosed it as faulty, boost solenoid, wastegate actuator, or waste gate flapper. They checked over tune and said it looks fine. Took for a test drive and was making boost then loosing it quickly so I thought the diagnosis to be fairly accurate.So went and replaced solenoid, still the same. Next ordered billett 12psi actuator, and while the turbo was off thought may aswell port the wategate out.Put it all back togther and it kinda better, but still way down on power. can not even spin up the wheels with traction control turned off. tested for boost leaks, replaced clamps and still the same.So why has it lost approx 70rwkw????Any help is appreciated. Hope I havent missed any detail Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/ Share on other sites More sharing options...
matt036 Donating Members 280 Member For: 15y 4m 20d Gender: Male Posted 01/09/13 11:39 AM Share Posted 01/09/13 11:39 AM (edited) This is a bit of a long shot but how long were the valve springs in the car before u bought it? Reason I ask is mine has a set of crow hd valve springs and last time I got it tuned we knew they were on there way out but held ok once we changed to e85. Although I noticed after a few weeks it just got doughier. I took it back to the tuner and wala down 60kw. This is just my case and maybe different to yours but its worth checkin it out as mine is doughy as fark comin on boost now and wont hold power over about 4500rpm.Also my valve springs werent quite 2 years old before they gave up the ghost. Edited 01/09/13 11:43 AM by matt036 Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420440 Share on other sites More sharing options...
rapid6turbo Member 56 Member For: 12y 1m 1d Gender: Male Posted 01/09/13 12:11 PM Author Share Posted 01/09/13 12:11 PM Ok, sounds interesting. Valve springs were fitted Jan 2011. I bought the car 6 months ago, so has always felt that way.Mine seems doughy aswell, can't even stall it up to spin the wheels, doesnt chirp 1st, 2nd shift.Surley valve springs would last longer than that?? On 01/09/2013 at 11:39 AM, matt036 said: This is a bit of a long shot but how long were the valve springs in the car before u bought it? Reason I ask is mine has a set of crow hd valve springs and last time I got it tuned we knew they were on there way out but held ok once we changed to e85. Although I noticed after a few weeks it just got doughier. I took it back to the tuner and wala down 60kw. This is just my case and maybe different to yours but its worth checkin it out as mine is doughy as fark comin on boost now and wont hold power over about 4500rpm.Also my valve springs werent quite 2 years old before they gave up the ghost. Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420455 Share on other sites More sharing options...
_Velocity_ Bronze Donating Members 2,768 Member For: 14y 1m 2d Gender: Male Location: Victoria Posted 01/09/13 12:19 PM Share Posted 01/09/13 12:19 PM (edited) Valve springs, blocked cat, boost leak, could be anything. Best to take it to a reputable shop and have it diagnosed properly before throwing anymore money at it. Also did you get a retune for the car after porting the wastegate and changing actuators? Is it breaking down at all through the powerband like traction control is kicking in or does it feel like its simply lost power? Edited 01/09/13 12:20 PM by _Velocity_ Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420461 Share on other sites More sharing options...
rapid6turbo Member 56 Member For: 12y 1m 1d Gender: Male Posted 01/09/13 12:25 PM Author Share Posted 01/09/13 12:25 PM I called the original tuner and he said check for blocked / collapsed exhaust etc. So put it over the pit, took the exhaust system off and ran straight out the dump pipe, no cat attached. although very loud still way down on power.Yeah, think I'll have to travel some distance to get it sorted. No retune for wastgate mod or actuator, is that really required? Traction control never kicks in.I still get good fuel economy thoughCheers On 01/09/2013 at 12:19 PM, _Velocity_ said: Valve springs, blocked cat, boost leak, could be anything. Best to take it to a reputable shop and have it diagnosed properly before throwing anymore money at it. Also did you get a retune for the car after porting the wastegate and changing actuators? Is it breaking down at all through the powerband like traction control is kicking in or does it feel like its simply lost power? Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420465 Share on other sites More sharing options...
rapid6turbo Member 56 Member For: 12y 1m 1d Gender: Male Posted 01/09/13 12:27 PM Author Share Posted 01/09/13 12:27 PM Visually the cat looked fine, dunno how to test its flow?? Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420467 Share on other sites More sharing options...
matt036 Donating Members 280 Member For: 15y 4m 20d Gender: Male Posted 01/09/13 09:34 PM Share Posted 01/09/13 09:34 PM On 01/09/2013 at 12:11 PM, rapid6turbo said: Surley valve springs would last longer than that??Mine were installed by a reputable tuner in August 2011 and yeah there shagged. I ol mate said best bet would be getting it to a reputable tuner. I have to drive at least 6 hours to get to one but it's worth it. Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420506 Share on other sites More sharing options...
rapid6turbo Member 56 Member For: 12y 1m 1d Gender: Male Posted 02/09/13 08:21 AM Author Share Posted 02/09/13 08:21 AM Are valve springs really that bad?? 2 year life span. It just doesnt sound right. Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420650 Share on other sites More sharing options...
bloosted Cruise Control 1,383 Member For: 19y 5m 21d Gender: Male Location: Adelaide Posted 02/09/13 08:30 AM Share Posted 02/09/13 08:30 AM On 01/09/2013 at 12:25 PM, rapid6turbo said: I called the original tuner and he said check for blocked / collapsed exhaust etc. So put it over the pit, took the exhaust system off and ran straight out the dump pipe, no cat attached. although very loud still way down on power.Yeah, think I'll have to travel some distance to get it sorted. No retune for wastgate mod or actuator, is that really required? Traction control never kicks in.I still get good fuel economy thoughCheersget it retuned with the new actuator before you hit boost again unless you want a new motor Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420654 Share on other sites More sharing options...
rapid6turbo Member 56 Member For: 12y 1m 1d Gender: Male Posted 02/09/13 09:42 AM Author Share Posted 02/09/13 09:42 AM Not wanting to sound silly, but it was running 12 psi with the old actuator & boost is controlled electronically. Putting on a 12 psi actuator to me would be the same. Am I wrong? Link to comment https://www.fordxr6turbo.com/forum/topic/86130-ba-mkii-xr6-turbo-down-on-power/#findComment-1420690 Share on other sites More sharing options...
