kaneoxr6t Member 70 Member For: 15y 24d Gender: Male Location: melbourne Posted 01/09/13 09:40 AM Share Posted 01/09/13 09:40 AM ok I know where is a shudder post already but that didn't help so when I brake soon as it hits 40 ks the front LH side starts to shudder I have changed the ball joint as it was dead thinking that was it but wasn't so I change the rotors and still have the shudder does any one know wtf is goin on lol doin my head it hard Link to comment https://www.fordxr6turbo.com/forum/topic/86129-need-help-going-nuts-brake-shudder/ Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 1d Gender: Male Location: Probably above atmospheric pressure Posted 01/09/13 11:43 AM Share Posted 01/09/13 11:43 AM What bushes are in there and how old? Link to comment https://www.fordxr6turbo.com/forum/topic/86129-need-help-going-nuts-brake-shudder/#findComment-1420442 Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 3m 28d Gender: Not Telling Posted 02/09/13 03:31 AM Share Posted 02/09/13 03:31 AM (edited) Hows your wheel bearings?Does it always shudder or do you have to drive for a little bit before it'll start shuddering upon braking? Edited 02/09/13 03:33 AM by johnxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/86129-need-help-going-nuts-brake-shudder/#findComment-1420565 Share on other sites More sharing options...
Hype Member 77 Member For: 11y 7m 24d Gender: Male Location: Canberra Posted 02/09/13 03:54 AM Share Posted 02/09/13 03:54 AM as above but check your wheel alignment as well Link to comment https://www.fordxr6turbo.com/forum/topic/86129-need-help-going-nuts-brake-shudder/#findComment-1420570 Share on other sites More sharing options...
F666E Member 29 Member For: 14y 21d Gender: Male Location: Perth Posted 17/11/13 11:17 AM Share Posted 17/11/13 11:17 AM I know it's been a while but I thought I could help... I had the same problem and it did my head in also!!! I tried everything and then it just clicked. Over tightening your wheel nuts puts too much pressure on the rotors. I bought myself a torque wrench and I torque my wheel nuts to 125nm every time now and haven't had a problem with it since. Give it a go hopefully works for you too... Good luck Link to comment https://www.fordxr6turbo.com/forum/topic/86129-need-help-going-nuts-brake-shudder/#findComment-1440850 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 5m 1d Gender: Male Location: Probably above atmospheric pressure Posted 18/11/13 05:15 AM Share Posted 18/11/13 05:15 AM You haven't been on a cruise in an even longer while mate Should come out more, show off that awesome car!I thought it was 135Nm, by the way? Or are FGs different? Link to comment https://www.fordxr6turbo.com/forum/topic/86129-need-help-going-nuts-brake-shudder/#findComment-1440969 Share on other sites More sharing options...
F666E Member 29 Member For: 14y 21d Gender: Male Location: Perth Posted 18/11/13 08:14 AM Share Posted 18/11/13 08:14 AM Haha I would love to come cruising more but we just moved to sunny Queensland! Pity I didn't come out with you guys more while I was in Perth! Mate I didn't know the torque setting for FG but trawled the forums and found the common setting was between 110 - 135nm so I just went somewhere in between. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86129-need-help-going-nuts-brake-shudder/#findComment-1441023 Share on other sites More sharing options...
vixenf6 Member 84 Member For: 11y 7m 13d Gender: Male Posted 18/11/13 12:18 PM Share Posted 18/11/13 12:18 PM Upper control arm bushes or Piston in master cylinder needs to be adjusted. Link to comment https://www.fordxr6turbo.com/forum/topic/86129-need-help-going-nuts-brake-shudder/#findComment-1441090 Share on other sites More sharing options...
