SeduceG6Et Member 26 Member For: 12y 5m 10d Gender: Male Location: Perth Posted 01/09/13 02:30 AM Share Posted 01/09/13 02:30 AM (edited) Hi guys. I am reasonably new to the whole turbo thing and also a Ford fan after a lifetime of being a Expensive Daewoo fan (V8's) so its great to read some of the threads to get some ideas. I now tell my Expensive Daewoo loving mates im not going to argue with you,just go and drive a late model XR6T or G6Et,lol. Anyway,I bought a G6Et late last year and had it tuned plus ID1000 injectors. It made 271kws. Tomorrow its going in for the Nizpro cooler,Nizpro stainless exhaust (4 inch)with dual cats,dump and actuator. Firstly,what sort of power do you guys (and gals) think I might achieve without going too silly,this car will never see a drag strip or race track.I have read some things about 4" exhausts droning but my tuner has said it will be fine so if anyone has this system it would be great to hear from you,thanks.Also,with traction being a bit of an issue now its only going to make it worse although im not a hoon I do like to punch it now and then. I have owned some high powered S/C V8's and have never done burnouts on public roads but I would like more traction to go along with the increased power. I have 18' in wheels,what is the widest tyres I could put on those legally.Any input would be awesome, Thanks again. Edited 01/09/13 02:31 AM by SeduceG6Et Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/ Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 22d Gender: Male Location: @ my laptop Posted 01/09/13 02:56 AM Share Posted 01/09/13 02:56 AM you will nee to port the turbo unless you want to run 16-18 psi in the mid 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420290 Share on other sites More sharing options...
SeduceG6Et Member 26 Member For: 12y 5m 10d Gender: Male Location: Perth Posted 01/09/13 03:39 AM Author Share Posted 01/09/13 03:39 AM (edited) On 01/09/2013 at 2:56 AM, ratter said: you will nee to port the turbo unless you want to run 16-18 psi in the mid Now that you mention it he did say something about porting the turbo and I just checked an email from when I was calling some tuners and it says something about porting the turbo bypass. Preferences§1234567890-=Backspace TabqwertyuIop[] Return capslockasdfghjkl;'\ shift`zxcvbnm,./shift English Deutsch Español Français Italiano Português Русский altalt Preferences Edited 01/09/13 03:41 AM by SeduceG6Et Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420300 Share on other sites More sharing options...
MurdoK Donating Members 719 Member For: 14y 11m 28d Gender: Male Location: Perth,WA Posted 01/09/13 03:47 AM Share Posted 01/09/13 03:47 AM made 300 with same mods. car will be very punchy around town from down low. At the time I decided not to port turbo and peaked at 16 in the mid as Ratter points out. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420301 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 24d Gender: Male Location: Probably above atmospheric pressure Posted 01/09/13 04:21 AM Share Posted 01/09/13 04:21 AM 18" rims have little bearing on width of tyre. You need to know the width of the rim. Factory are 8" wide so usually the widest people go is 255 but I think that is pushing it? 235 and 245 are common. Wider than that and you're looking for wider rims. You could also get an LSD put in her.Look into the tyre threads to see what other people have to say about brands. I've used Kumho KU31 and Nitto Invo with good results and low 300's rwkw. Due to your smaller turbo you will spool faster and possibly break traction a little easier, so KU31's might not be good enough. Both tyres can be had cheap if you look around, site sponsor Taleb Tyres for example, or I get my KU31's fitted at KMart Tyre N Auto for cheap too (17" size but 235/45 width and profile, fitted and balanced for 169ea). If you are willing to pay then you can get great grip, again look in the tyre threads.Congrats on making to move over to boosted Fords! Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420312 Share on other sites More sharing options...
JMJR10 Member 79 Member For: 13y 8m 10d Gender: Male Posted 01/09/13 06:13 AM Share Posted 01/09/13 06:13 AM I wouldn't bother modifying the turbo get the nizpro cooler and nizpro exhaust and get the surge tank aswel that nizpro use Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420351 Share on other sites More sharing options...
AdamIan69 Bronze Donating Members 401 Member For: 12y 1m 27d Gender: Male Location: WA Posted 01/09/13 07:50 AM Share Posted 01/09/13 07:50 AM (edited) I found in my g6e turbo that I have never done a single spinner from accelerating too hard. It has always kicked double leggars. I found that it is only when the car is going through a "snakey" that the G6E diff will spin one wheel 50% of the time but only when the rear end is sliding to the left, it will then kick double again when the ass slides to the right which makes getting the car under control from a out of control situation a bit of a mission. So IMO I don't think a LSD/locker(trutrac) will help in keeping the tyres from spinning, but it will help stop the car from performing differently when sliding from one side to the other. I have not had much experience in finding grippy tyre as I always buy one of the cheaper tyre brands for the rear.My G6E T is making about 400-410rwkw(made 380rwkw while spinning the tyres 600rpm faster then the dyno rollers and was told that would be about 30rwkw of loss) and I think that the main reason why my tyres break loose while driving hard is that I have had the G/box tuned and it now changes up gears very firmly, therefore starting the tyre spin. Edited 01/09/13 07:52 AM by AdamIan69 Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420383 Share on other sites More sharing options...
SeduceG6Et Member 26 Member For: 12y 5m 10d Gender: Male Location: Perth Posted 01/09/13 08:31 AM Author Share Posted 01/09/13 08:31 AM (edited) On 01/09/2013 at 4:21 AM, -SteveR- said: 18" rims have little bearing on width of tyre. You need to know the width of the rim. Factory are 8" wide so usually the widest people go is 255 but I think that is pushing it? 235 and 245 are common. Wider than that and you're looking for wider rims. You could also get an LSD put in her.Look into the tyre threads to see what other people have to say about brands. I've used Kumho KU31 and Nitto Invo with good results and low 300's rwkw. Due to your smaller turbo you will spool faster and possibly break traction a little easier, so KU31's might not be good enough. Both tyres can be had cheap if you look around, site sponsor Taleb Tyres for example, or I get my KU31's fitted at KMart Tyre N Auto for cheap too (17" size but 235/45 width and profile, fitted and balanced for 169ea). If you are willing to pay then you can get great grip, again look in the tyre threads.Congrats on making to move over to boosted Fords!I shopped around and went with the Kuhmo KU22,they are still like new as I only drive the car on weekends but it still breaks traction when it hits second gear. As standard they do that flutter thing between gear changes,maybe the tuner can make it so its not so aggressive or just backs off a little as it changes,I dont know,the turbo stuff is still new to me but im learning. Preferences§1234567890-=Backspace TabqwertyuIop[] Return capslockasdfghjkl;'\ shift`zxcvbnm,./shift English Deutsch Español Français Italiano Português Русский altalt Preferences Edited 01/09/13 08:33 AM by SeduceG6Et Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420391 Share on other sites More sharing options...
MurdoK Donating Members 719 Member For: 14y 11m 28d Gender: Male Location: Perth,WA Posted 01/09/13 08:34 AM Share Posted 01/09/13 08:34 AM (edited) On 01/09/2013 at 8:31 AM, SeduceG6Et said: I shopped around and went with the Kuhmo KU22,they are still like new as I only drive the car on weekends but it still breaks traction when it hits second gear. As standard they do that flutter thing between gear changes,maybe the tuner can make it so its not so aggressive or just backs off a little as it changes,I dont know,the turbo stuff is still new to me but im learning. Preferences§1234567890-=Backspace TabqwertyuIop[] Return capslockasdfghjkl;'\ shift`zxcvbnm,./shift English Deutsch Español Français Italiano Português Русский alt alt PreferencesHow you do that Edited 01/09/13 08:35 AM by MurdoK Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420393 Share on other sites More sharing options...
wombatG6ET Bronze Donating Members 707 Member For: 13y 6d Gender: Male Location: cherrybrook Posted 01/09/13 08:39 AM Share Posted 01/09/13 08:39 AM Hi mate, what's happening with your posts, it puts up a lot of weird letters and numbers coming down the screen, or is it my ipad getting some weird post But anyway nice looking car, but I might be a bit biased to the model and colour Link to comment https://www.fordxr6turbo.com/forum/topic/86124-271rwkw-g6et-more-mods-your-thoughts/#findComment-1420394 Share on other sites More sharing options...
