  • Member For: 11y 9m 7d
Hi All,
Been searching forums for a few months now since purchasing my Territory Ghia. Picked up a non turbo with low K's for really cheap so it is not really viable to sell it to get a turbo considering the price I got it for.
Now I am looking for ways of making some cheap power. Just a bit more punch (and probably get the bug and go all out later)
Currently putting in a set of Hertz 6" splits front and back, amp upgrade and custom sub box in the back (upgrade the stock) and a new head unit.
Any advice in give my Terry a bit of kick would be greatly appreciated.
https://www.fordxr6turbo.com/forum/topic/86110-turbo-or-supercharge/
  • Member For: 12y 4m 20d
Mate, even though you say its not viable to buy a TT, if you got your N/A cheap enough and can make a profit on it, the money you'll spend to make it SLIGHTLY quicker would be better spent on upgrading to the turbo model (which will be considerably quicker) IMHO.
  • Moderating Team
  • Member For: 22y 4m 6d
What trans has it got? 4 speed or ZF?
That will dictate what you do.
Im not sure if the N/A 4 speeds and T 4 speeds are the same? If the N/A 4 speeds are weaker, you wont be doing much.
Thanks Guys.
My current terry goes well, but could do with a little pep in its step (mainly down low).
What kind of mods would one look into if I where to keep it n/a and just give it a little more punch. I have already replaced the air filter, and was exploring a high flow cat.
Ultimately I am just after a nice running car with a little pep, not really a flying barge. :)
  • Bronze Donating Members
  • Member For: 12y 1m 15d
If it is a two wheel drive, you could put a higher ratio diff in it with our being too expensive. Around $500 for gears plus install.
  • 1 year later...
  • Member For: 11y 5m 30d
if it has a btr youll need to edit the tune with a diff raito swap. building a turbo na engine like you originally said would be the go, otherwise the usual headers/exhaust/intake mods and call it a day
Edited by luke187
