BRK Member 361 Member For: 13y 6m 5d Gender: Male Location: Perth Posted 30/08/13 03:08 AM Share Posted 30/08/13 03:08 AM (edited) I hope the up load has taken properly and I know it is side on but anyway it looks to be there.IMG_20130830_0004.pdf The torque is good and flat at 14 psi ( then tapering to 12) but it just rolls over at the top end - boost control is blamed. No amount of fiddling with timing/boost and cam timing helps. Using VCM suite.Intercooler (using F6 factory gear) or port flapper with bigger injectors (Currently using Bosch 440cc) ?? Edited 30/08/13 03:13 AM by BRK Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/ Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 8m 27d Gender: Male Location: Perth, WA Posted 30/08/13 03:52 AM Share Posted 30/08/13 03:52 AM What actuator are you running? You need more then 12psi up top to crack 300rwkw, I had the same issue with my old BA running a stock actuator. Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/#findComment-1419938 Share on other sites More sharing options...
BRK Member 361 Member For: 13y 6m 5d Gender: Male Location: Perth Posted 30/08/13 04:03 AM Author Share Posted 30/08/13 04:03 AM 12 psi actuator. Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/#findComment-1419940 Share on other sites More sharing options...
Turkey91 Member 57 Member For: 12y 9m 29d Posted 30/08/13 04:06 AM Share Posted 30/08/13 04:06 AM My last car managed a steady 15psi with standard turbo and actuator. Unless my boost gauge was wrong. Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/#findComment-1419941 Share on other sites More sharing options...
BRK Member 361 Member For: 13y 6m 5d Gender: Male Location: Perth Posted 30/08/13 04:16 AM Author Share Posted 30/08/13 04:16 AM It is just so annoying. The power curve builds well and the torque curve is flat - but once up in the rev range, it pings. So we have to modify the tune and after lots of options already tried, that means dropping the boost back. If boost is raised any more earlier in the rev range, it cannot be controlled in the mid range. I don't care about spending more money on it but the right direction is important. Once it goes over 300, that will be enough. I think injectors and waste gate mods - but if an intercooler would do it, then that is cheaper and slightly easier fitting wise. Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/#findComment-1419943 Share on other sites More sharing options...
Slymeat Team Kickass Donating Members 1,926 Member For: 21y 4m 21d Gender: Male Location: Albion Park, NSW Posted 30/08/13 04:23 AM Share Posted 30/08/13 04:23 AM (edited) Intercooler time. Edited 30/08/13 04:24 AM by Slymeat Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/#findComment-1419944 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 25d Gender: Male Location: Probably above atmospheric pressure Posted 30/08/13 04:32 AM Share Posted 30/08/13 04:32 AM (edited) On 30/08/2013 at 4:06 AM, Turkey91 said: My last car managed a steady 15psi with standard turbo and actuator. Unless my boost gauge was wrong.Same here. Really glad I didn't need to spend more for the result (as great as a wastegate and flapper mod with actuator change would be).Nizpro cooler, probably overkill for my levels. 42lb Bosch green top injectors, standard intake (F6 snorkel mod) and Manta 2x2.5" exhaust (also not really needed, dump and cat would do it) Edited 30/08/13 04:35 AM by -SteveR- Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/#findComment-1419945 Share on other sites More sharing options...
Turkey91 Member 57 Member For: 12y 9m 29d Posted 30/08/13 05:28 AM Share Posted 30/08/13 05:28 AM I had process west stage 2 kit. 60 pound injectors And no cat. Oh and fuel pump. Had 309 with those mods. Then turbo blew up. Got a bigger one with actuator then had dramas ever since with trying to keep from over boosting. No one in darwin will do the wastegate mod. Gotta send turbo away. Which is inconvenient Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/#findComment-1419965 Share on other sites More sharing options...
envyxr Member 201 Member For: 16y 7m 13d Gender: Male Location: sunshine coast Posted 30/08/13 09:58 AM Share Posted 30/08/13 09:58 AM (edited) -60lb Siemens injectors-high flow 100cell cat and remove your centre muffler -F6 cooler will do the job.-don't worry about the flapper mod just a 12lb actuator and a gs3441 in tank pump- start it at 15 lb and trail down to 12 and you should make the numbers Edited 30/08/13 09:59 AM by envyxr Link to comment https://www.fordxr6turbo.com/forum/topic/86107-the-next-step-to-get-300rwkw/#findComment-1420012 Share on other sites More sharing options...
