nelsonian101 Donating Members 961 Member For: 16y 9m 20d Gender: Male Location: Sydney Posted 01/09/13 12:13 AM Share Posted 01/09/13 12:13 AM If you sprayed the rear leaf bolts with wd4o and tightened them, noise went away then came back.Soultion: respray and retighten.Front end noise: Change front wheel bearings. Link to comment https://www.fordxr6turbo.com/forum/topic/86040-starting-to-drive-me-up-the-wall/page/2/#findComment-1420248 Share on other sites More sharing options...
Swindog Member 40 Member For: 11y 8m 6d Posted 01/09/13 05:45 AM Share Posted 01/09/13 05:45 AM Wheel bearings are easy to check instead of chucking dollars at it though. Jack it up and give the wheel a few jiggles etc. Youll soon know if theres play or slop if its a wheel bearing. Link to comment https://www.fordxr6turbo.com/forum/topic/86040-starting-to-drive-me-up-the-wall/page/2/#findComment-1420331 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 3m 29d Gender: Male Posted 01/09/13 07:20 AM Share Posted 01/09/13 07:20 AM I had what seemed to be a front end knock, turned out to be the diff bush. I realise yours is a ute so obviously not that, but perhaps its not where it seems to be? Link to comment https://www.fordxr6turbo.com/forum/topic/86040-starting-to-drive-me-up-the-wall/page/2/#findComment-1420381 Share on other sites More sharing options...
kylec New Member 15 Member For: 11y 6m 23d Gender: Male Location: Adelaide, SA Posted 13/10/13 03:00 AM Share Posted 13/10/13 03:00 AM Check the lower control arm ball joints. I had the same issue with creaking/squeaking/grinding while turning. Got them replaced and all quiet again Link to comment https://www.fordxr6turbo.com/forum/topic/86040-starting-to-drive-me-up-the-wall/page/2/#findComment-1432677 Share on other sites More sharing options...
